6.7 seems sluggish after egr delete
What's up everyone I installed a sinister delete kit on my 6.7 f350 today and everything is good but after the delete seems like the truck takes a little longer to spool and go ! I had to pull the to manifold and front aluminum piece off to be able to tap the bolt that snapped off also I double checked all nuts and bolts and I'm stumped any ideas ? It has a CRT pro and PDF delete on it also was fine till the delete ! Thanks for any help guys
Was the it already tuned and deleted before removing the egr cooler? If all you did was delete the egr then it rules out tuning and i would lean towards you have an exhaust leak somewhere on that manifold you had to take off. This is assuming the lag wasn't there when tuned and deleted before removing the egr and that was all you did.
