Silence of the Cabs
Love the Title
Enjoyed the title as well.
I would also be interested in hearing (pun intended) what people have done.
I can tell you what didn't help......4" down pipe to 5" magnaflow......didn't help the sound in the cab.
My wofe and I decided this weekend after a trip up here to our cabin that 4 hours the max to be in the black beast without a rest period.........
How do you guys apply/install the sound deadening, pull the whole headliner etc.?
I did the Fatmat install about 10 yrs ago. I did the entire cab, A-pillars, up the back, including the inside and outside of all 4 doors, as well as the firewall from the engine bay side. It did make a big difference, but with a 4" exhaust, no muffler, 35's w a 6" lift, and a 38R w 238/80 injectors it's still gonna be alittle little loud. The biggest difference it made was with my stereo, it sounds amazingly tight.
If anyone is considering doing this, you won't be disappointed.
Ford turbo and TQ converter 008 by countrycar - Ford-Trucks
Dunno how much it will help but when i put the new hood on i ran for a few months without the underhood fiber matt thing that body clips up there. I had pulled it from the busted up hood and sprayed it with bedliner. It had just been sitting outside waiting for me to remember to swing by a parts house for some body clips. When i did remember and finally got it installed, the noise decrease was astounding!
Thats about as far as my efforts to quiet in cab noise have ventured.
Anything that gets air out of fuel helps, tuning, proper running engine, hood insulation, fix leaks (air and exhaust), Lariat trim, etc.... That's all I've done or was in the truck already. I might do the floor matt stuff - it's higher on the priority list than the steering wheel and the headlights.
I did the Fatmat install about 10 yrs ago. I did the entire cab, A-pillars, up the back, including the inside and outside of all 4 doors, as well as the firewall from the engine bay side. The biggest difference it made was with my stereo, it sounds amazingly tight.
It's funny how quickly your description reads... all of 4 seconds to read your post... when you are describing 4 days of labor, at least.
For those who couldn't see the picture in his post, here it is:
My truck is an 02 and I think the 02 and newer trucks are just quieter to begin with, but I did the door seal mod anyway. I can't really say it made a noticeable difference in air sounds on the highway but one thing it DID stop was an annoying door thump I would get while bouncing over rough terrain. Like Tugly says there are lots of things you can do to keep the engine noise to a minimum as well. My engine is very quiet and I can easily pass the Bic lighter test at 80 MPH climbing a grade. Sometimes I lower a window at a red light just so I can hear it!
The later 2002-2003 models had a lot of insulation in the interior doors panel trim, pillar and mirror garnish trim, headliner trim on the ceiling side, under the dash, along the firewall, under the transmission tunnel, under the hood, in the engine compartment, and in the fenders... that the 99-01 models didn't have.
