Vacuum leak found
Vacuum leak found
So I was rebuilding the carb again with the Ford Kit this time. Much nicer than that generic one I had before. Worth the wait. This time I pulled off the spacer too and while undoing the coolant lines the vacuum line to the brake booster just snaps off the manifold elbow. It was as brittle as it could be right there, and it was full of carbon. So all new hoses for under the hood. Normally that's the first thing I replace, but these did not look that old. Turns out the vac line was probably original. I could tell from the cross section that it had been leaking for a while. So now I have a fighting chance at getting it to idle properly. That also explains why the spray test did not shoe any leak around the carb base. Still going to test the booster for leak. It definitely works, but that doesn't mean it doesn't leak.
78 Ranger
08-03-2005 11:26 PM
johnsalterego
08-03-2003 11:00 AM
