Is this turbo ok?
Is this turbo ok?
I'm working on the turbo in my E99 and was replacing the stock wheel with a billet that I got from Clay cause my stock one got dusted from a K&N air filter. I wasn't planning on doing a turbo rebuild kit cause as I am trying to save up for the late 99 conversion kit from Riffraff, probably won't happen for a couple of months though. Is this turbo salvageable until the upgrade and do you think the 75$ rebuild is a must? Any advice would help.
As Dan said it looks like just the casting, if the play doesn't allow the wheel to contact the housing, and there is no in/out play, the turbo will likely be fine.
I would want to do a compression test at somepoint before you go into adding more power such as injectors, which as a health check I would do anyway even on a non-dusted appearing motor.
