76 360 C6 Starter issues
Old May 22, 2014 | 03:25 PM
AZRRC's Avatar
AZRRC
my starter was working great until the exhaust shop noticed the ears were cracked. i brought a starter from autozone and had them install, since then the starter has made a ton of noise and now slips and grinds, i can turn the motor by hand and sometimes it will start sometimes it will grind. i have removed the inspection plate and the teeth look ok none are missing. it almost looks like the starter sits too far out.
the ring gear has 184 teeth and the starter has 9 teeth.
does anyone have a suggestion on what could be causing this issue?
the exhaust shop had noted that there is no block plate between the motor and tranny.
the truck is a 76 f150 4x4 auto
Fireater1968
Apr 22, 2019 06:51 PM
Furr308
18
May 5, 2015 10:19 AM
ginch66
Nov 6, 2011 01:41 AM
daveeich337
25
Mar 3, 2008 07:37 PM
123michigan
Jan 2, 2005 09:13 PM
