New Warning To All Ford Ecoboost Owners!
Soot doesn't cause permanent damage. The video says that some chemicals that people clean their intake/valve train with can damage the turbos. However, I haven't read about any Ecoboost F150s that suffered from carboned up valves. Even the "Hero" engine didn't have carboned up valves when they tore it down with 162k (simulated) miles.
At least that's as far as I understand it.
From what I gathered from reading about this in the past, the version used in the F150s does not use an EGR system because these engines have Ti-VCT that's used in its place. Because you're not recycling exhaust gasses the soot doesn't enter the intake. Other variants of the EcoBoost engine, such as the ones found in the SHO Tauri and Flexes don't have the same cam phasing system. So to meet emissions regulations they need to use EGR, which can gum up valves when not washed down with fuel.
Thank you for the heads up about the turbo's & upper intake cleaning! I have been researching this problem with gdi engine for a couple of months now. From what i understand the problem stems from the crank case vapors being suck back into the engine through the pcv system. So when you shut down the engine the oil vapors condense down on the back of the intake valve & bake on! As most of you know the gdi engine do not have an injector behind the intake valve so it can not get wash off when the engine is running. Thats why it is so critcal to change the engine oil no later then 5000 in order to keep the the piston rings clean, so they seal good aganist the cylinder walls to prevent excessive blow-by. My too cents worth. p.s great forum everybody here is awsome. I have learned alot from everybody.
Not sure the early oil change will help this issue. Also not sure this is much of an issue at all. Unless the build-up prevents the valves from seating, the only downside is how pretty the parts look if you take the engine apart.
Haven't heard a mention of valve problems from this buildup in these engines, not even in this thread. In fact, the video mentions that it HASN'T been an issue.
I plan on making no special efforts to prevent this non-issue.
