need more power going up mountain
I have a 450PSD, 2002, 7.3, 2WD, CC, auto tranny, and I pull a 5th wheel trailer. It weighs about 13K. Often going up a steep mountain I will get down to as low as 35mph. Not too bad but I've been wondering if a larger exhaust and larger air intake would give me just a little bit more umpth to get up and over the mountain. Currently everything is stock. Thanks, HamRad
Those will help only a very tiny bit if at all. What they will allow for is getting a chip with a nice tow tune on it which will help out a bunch. How steep of a grade are you pulling? Those 4:88's and "only" 13k lbs even stock should pull that weight decently unless it is very steep. How long have you had the truck?
Thanks for quick input folks. I'm looking for 45MPH..... No less. The grades I'm talking about are only in the 6 to 8% range. Basically the Grapevine on I-5 and Mt. Shasta and on up into OR over Mt. Ashland or whatever it is called.
The motor should be just about on specs. I've had the truck since it was new. It does have the 4:88's. As far as I know it does not have any "leaks" but I don't know that for certain. I'll get that checked.
Appreciate all the input and I like the idea of getting it chipped for a better tow. Thanks guys. HamRad
You have something wrong if you are pulling those grades with that weight and can't maintain 55, much less 45. I would look into it. I would suspect boost leak first like Dan mentions, then up pipes leaking, and then maybe a fuel pressure issue and probably a combination of a couple of those things.
F450s like the vans usually have steel tanks, which when they delaminate can cause a fuel restriction which on mine at least showed up when traveling uphill pulling a trailer, because the engine needs a lot of fuel to sustain the load. I am not saying it is your problem, but it would be worth ruling out by pulling your oem fuel/water separator filter and looking to see how clean it is and what color it is if it is not clean. And it wouldn't hurt to drop the tank and look at the in-tank screens as well. You have a 12 year old steel tank which is what I had.
For my experience you can see:
https://www.ford-trucks.com/forums/1...fuel-tank.html
Good luck and please post your results!
