Soot and Oil Near Turbo - where to start
Old 05-20-2014, 08:05 AM
tjmike
tjmike is offline
tjmike is starting off with a positive reputation.
I have some soot and oil near the turbo and soot on the cooler pipes near the radiator. I assume some action should be taken, but I'm not positive where to start.
Here are some photos:
Old 05-20-2014, 08:15 AM
Dan V
Dan V is offline
Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.
Pretty normal given the age of these things...Some Simple Green and low pressure water, clean it. Order some CAC boots from Riffraff, all 6 of them, install....have a beer.
Old 05-20-2014, 10:36 AM
Icicle's Avatar
Icicle
Icicle is offline
Icicle has a good reputation on FTE.Icicle has a good reputation on FTE.Icicle has a good reputation on FTE.
Yeah, I would just say you need new boots. If it's leaking oil and soot, it's also leaking fresh air.
Old 05-20-2014, 10:40 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
JOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud of
In the second picture it looks like a puddle, is it? If so it's time to pull that turbo off and replace those orings.
Old 05-20-2014, 11:07 AM
tjmike
tjmike is offline
Yes, I'm getting some oil in the valley under the turbo. So two possible issues, 1) replace the boots and 2) track down oil source - which is likely not the boots?
For tracking down the oil, I guess the most likely candidate is at the base of the turbo. So clean up that area and watch to see where the oil is coming from to see if it's forming there. Is there some other possible source for the oil?
Old 05-20-2014, 11:14 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
You got it! Simple green goes a long way for these kind of messes.
Oil should not be flowing through your intercooler pipes at a rate to make a mess if you clean under the hood once In a great while. The only oil that would be in there would come from your crank case vent that's routed into the intake.
Old 05-20-2014, 11:51 AM
Dan V
Dan V is offline
If you find yourself looking real deep under the turbo to find said leak/weep...pay close attention to the EBPV actuator....known to leak. They can be rebuild, whether or not people have luck rebuilding them? Can't say.
If you find the leak between the turbo and the pedestal, o-rings, It would be prudent to remove the pedestal as well and replace the or-rings pedestal to the block....You're right there, it's just another set of o-rings. You'll strangle yourself if you go in that far, don't change them, and they start leaking.....cuz it was another 10 minutes and $7.
Gicknordon
64
11-18-2017 11:26 AM
CTom
30
08-28-2014 03:38 PM
salf100
09-09-2011 12:17 PM
kpmalone
1999 to 2016 Super Duty
04-01-2010 08:49 PM
supersle
Modular V10 (6.8l)
03-04-2010 01:29 PM
Quick Reply: Soot and Oil Near Turbo - where to start
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
