2011 4.6ltr with CV IFS in 1969 F100, Engine height discussion
Hi all, I have a 2011 4.6ltr V8 and CV IFS that Im swapping into my 69 F100. With the engine in its original mount holes in the CV IFS, it sits SUPER low in the chassis and doesnt line up with the rad/rad opening. Im wondering what others have done with this particular issue
Original mount holes;
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/040_zps1e7f9c7c.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/040_zps1e7f9c7c.jpg" border="0" alt=" photo 040_zps1e7f9c7c.jpg"/></a>[/IMG]
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/041_zps413303c1.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/041_zps413303c1.jpg" border="0" alt=" photo 041_zps413303c1.jpg"/></a>[/IMG]
I have added a 4" spacer to these (motor mount not done...haha just mocked up ) and this lines up the nicest in my opinion
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/022_zpscc918da8.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/022_zpscc918da8.jpg" border="0" alt=" photo 022_zpscc918da8.jpg"/></a>[/IMG]
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/024_zps4d9a4122.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/024_zps4d9a4122.jpg" border="0" alt=" photo 024_zps4d9a4122.jpg"/></a>[/IMG]
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/027_zps4bec2125.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/027_zps4bec2125.jpg" border="0" alt=" photo 027_zps4bec2125.jpg"/></a>[/IMG]
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/032_zps553a9273.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/032_zps553a9273.jpg" border="0" alt=" photo 032_zps553a9273.jpg"/></a>[/IMG]
By raising the engine 4" and retaining the stock CV tranny X-mbr bolted to the underside of the top frame rail, nets an angle of 4 degrees to the rear
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/023_zpsc73108c5.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/023_zpsc73108c5.jpg" border="0" alt=" photo 023_zpsc73108c5.jpg"/></a>[/IMG]
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/010_zps54a9a351.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/010_zps54a9a351.jpg" border="0" alt=" photo 010_zps54a9a351.jpg"/></a>[/IMG]
I havent cut any hoses yet but you can see how well everything lines up
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/033_zps0e9fc191.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/033_zps0e9fc191.jpg" border="0" alt=" photo 033_zps0e9fc191.jpg"/></a>[/IMG]
I retained the stock CV lower rad support
[IMG]<a href="http://s1172.photobucket.com/user/cccreations1/media/036_zps4b4147a2.jpg.html" target="_blank"><img src="http://i1172.photobucket.com/albums/r567/cccreations1/036_zps4b4147a2.jpg" border="0" alt=" photo 036_zps4b4147a2.jpg"/></a>[/IMG]
Anyways enough rambling. Let me know what you guys think. Thanks !
I am thinkin' all will be fine after you get your rear end in at the correct pinion angle to match the tranny. You raised the engine/tranny UP to approx old ones were. So I am assuming all will be well with the firewall and floor. And lowering the rear suspension effectively raises the rear end up closer to the height of the tranny. My .02.
Also I remember there was somebody else that put in a C/V 4.6L quite a few months back. I can't remember who. I also can't remember what he did on engine heighth. I remember he fitted the C/V cluster behind the Bump dash bezel. Fitted surprisingly easy. If I remember right he did it for looks and because some of the power,controls,wiring etc for the C/V PCM goes through the cluster. If that's a clue to find his build.
I would leave the engine low, But I also under stand that by raising the engine it makes the exhaust and other items fit a tad better.
If it was me I would be setting the engine low in the chassis and moving it rear ward as much as possible. and using electric fans to handle the cooling job
Thanks for all the great info ! I completely agree that until the cab gets here there is not alot more I can do, seeing as I dont know where Im actually able to fit the engine/tranny. I understand the center of gravity being higher means Ill lose some maneuverability however I feel the truck will still drive WAY better than the original and it clears all my exhaust and fills the engine bay ( yes, aesthetics ....haha) Id be very interested in pictures of the finished 4.6 in that engine bay at stock height or even Saturn5 engine thats been moved rear ward 3". Thanks again guys and Ill be sure to update my progress. Also, if anyone is needing a C4 tranny or a CV IFS give me a PM !
Pass side
Driver's side. I will have to relocate the oil filter, but I planned on that anyway.
You can see how much space opens up front now.
Shifter location with a T45.
Engine is about 1 1/4" off the firewall. I also needed to rework the crossmember under the firewall to clear the bellhousing.
