F150 dragging front brakes
Oh most knowledgable Ford folks, on a 1998 F150 2 wheel drive 4.6 250k, the front brakes will drag under a specific set of circumstances; only in prolonged stop and go traffic with hot ambient temps. Rotors, calipers, rear shoes, drums, fluid, bearings, seals have all been replaced. This occurs only a couple of times a year, otherwise the brakes work perfectly. It starts out as a slight shimmy that worsens until you can smell the pads cooking and the wheels are hotter than hell. The truck will hardly move at times. The rears are normal. After the truck cools for hours, no symptoms. Any thoughts or experiences? Thanks.
I had this happen on a 1998 2x4 with 388000km on the front left. A mechanic told me the clamp holding the brake hose will rust so much on the inside it clamps off the hose. Hydraulic pressure forces the fluid through the hose when braking but is restricted when released. I cleaned the rust out of the clamp and the brake works fine.
lonewolf121
13
02-16-2012 09:02 AM
J1MMY
16
09-22-2008 04:50 PM
