Transmission temp wiring - P0713
Old 05-17-2014, 01:51 AM
chewedtoothpick's Avatar
chewedtoothpick
chewedtoothpick is offline
I have been having an intermittent 0713, which I believe I have narrowed down to a chafed wire. I already replaced the sender, and when running, if I push this cable the temperature goes haywire - or when I am going over the glorious California roads...
Before I go through the hassle of striping all the wire bundling etc to solder on a new wire, can you verify that the attached picture is of a wire bundle that is likely to actually have the transmission temperature wire, or if there is a better option for doing this?
Also, what moron at ford thought this was a good idea??
RustyTank
06-13-2019 02:44 PM
3twinridges
17
06-09-2019 02:25 PM
hot-rod
13
10-28-2016 08:02 PM
beersy50
02-13-2011 07:37 PM
john fin
02-05-2009 04:41 PM
Quick Reply: Transmission temp wiring - P0713
