Tow small trailer with rear bumper?
on
I know this question has probably been worn out to a T but I will ask it anyways.
I own a 88 F150 4x4 302 reg cab long bed truck whom I prefer to keep in good shape and not tow in the bed and only light trailers. I recently picked up a stronger, more reinforced rear bumper for it since it needed a bumper. I don't want to mess this bumper up as I really like it and is one of the only ones I can find like it.
I want to be able to tow my 3 motorcycle trailer which is all steel with my 73 Harley (not sure what it weighs but it is customized and probably weighs only a few hundred pounds less then my dad's bike), My dad's 07 Harley Davidson Heritage softail, and a similar bike to my Harley or a small pit bike that I have that weighs maybe 200-250lbs if that.
Do you think I should tow them with a hitch receiver or will I be fine with towing with my rear bumper. I don't want to add a hitch if I don't have to as then it probably will start being used as a truck to tow with and I don't want that.
I am not worried about my truck pulling it or not I am mainly worried about the bumper holding up or not.
Thanks guys
Trav
EDIT: my dad's bike weighs about at 800 or so pounds and mine weighs 600 or 700 lbs without the sissy bar and windshield.
Thanks guys
Trav
on
on
Thanks for that info Paul. the big loads I got other trucks to tow so I won't be much more a couple thousand pounds.
Do you think my 302 if it was running great with my 3.55 gears and 31s will be comfortable towing that around a couple hundred to 300 miles with a few decent sized hills?
Trav
Trav
I would definitely recommend going for the front hitch receiver - Reese Hitches has a good selection of them for Ford. Better safe than sorry and then you won't have to worry. They are usually pretty easy to install, too.
on
Trav
2001gocougs
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
13
12-10-2006 10:15 PM
F150Guy87
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
11-30-2004 07:18 PM
shermdog
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-01-2003 07:23 PM
