91 F250 Fuel Pump
Old 07-07-2014, 05:55 PM
Harold Lee's Avatar
Harold Lee
Harold Lee is offline
91 F250 Fuel Pump
The pump on my 91 F250 EFI will not shut off when the truck is shut off. Any suggestions? Thanks!
Old 07-07-2014, 06:27 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Is this a new issue? Did it shut off in the past?
Old 07-07-2014, 06:29 PM
carguy94's Avatar
carguy94
carguy94 is offline
will the truck start. pull codes from the engine. if your fuel pump will not shut off unless their is a wiring short or something in between the EEC then that could be bad causing the pump to run all the time. do you know were the diagnostic test port is on your truck and the one in the cab.
Old 07-07-2014, 06:36 PM
subford's Avatar
subford
subford is offline
If the key is also off you may have a stuck EEC Power or Fuel pump relay. Also check the wiring under these two relays mounted on the drivers inter fender.
Echelon
12-06-2014 06:55 PM
deanna197
05-28-2011 08:21 AM
wilsonjoey22
10-18-2009 08:15 AM
jas88
1978 - 1996 Big Bronco
04-01-2008 09:49 AM
Ohio Farmer
10-26-2004 11:35 AM
Quick Reply: 91 F250 Fuel Pump
