1989 6 cyl f-150 stalling
My Bros 1989 f150 6-cyl has had problems since he got it running after sitting for a few years. The fuel system has been cleaned out (tanks and lines). Fuel pressure is good. Distributor is new. New plugs/wires. It stalls when it sits at idle when the engine is warm. Runs rough if it restarts then finally dies. But when it is driven on the highway at highway speeds, it runs fine. Only when he comes to a stop and sits does this happen, as if it doesn't get enough cooling to a faulty sensor. Restarts fine after cooling down. He has taken his truck to three different mechs. They have all charged him several hundred dollars without any fix. No codes. Inspection for leaks around the intake have been check by previous mechs and a new egr valve has been changed. New hoses and lines have been replaced. The passages for the egr valve have been inspected and cleaned as well (as claimed). Any Ideas?
Thanks UB for replying. I hope spending several hundred dollars that he did have the vacuum lines checked out. If not, I will have a beef with his mechs. My brother was a prior diesel mech but isn't updated with electronics. If it were a vacuum leak, I'm sure he would have found it or at least, looked for it. I'll give him a call and ask him for more detail and post it.
