460 EFI head question
Old Jul 6, 2003 | 07:01 PM
gabraham's Avatar
gabraham
Hi I was thinking of dropping a EFI 460 into a 1988 ford bronco. I can score a 1975 460 short block for cheap and was wondering if the EFI 460 heads would bolt up to the 1975 short block so that I can install the EFI 460 intake manifold. I know I can't use 1975 heads with the EFI intake manifold, won't get a good seal. Need some info before I make a mistake. Thanks guys
Old Jul 6, 2003 | 07:41 PM
HdPSD's Avatar
HdPSD
I asked the same question on a different forum
you need a intake lower&upper wiring harness computer and more....
YOU might want to contact No Email Addresses In Posts![/b])]Nathan Geving
Old Jul 7, 2003 | 08:11 AM
gabraham's Avatar
gabraham
Yes but do the EFI 460 heads bolt up to the 1975 block with no problems.
Old Jul 7, 2003 | 02:45 PM
bigsnag's Avatar
bigsnag
Should bolt up no problem. The only difference between blocks of different years was the deck height. Early ones were 10.0, then 10.3 then 10.32, (I think). That's just going off the top of my head. I think anything after 1972 is the tall deck height.
JJ
Old Jul 7, 2003 | 11:58 PM
ludis's Avatar
ludis
The 75 short block will be internally balanced and you'll need to use its matching flywheel/flexplate and crank spacer. Also, the pistons won't be the same as EFI pistons and hence your compression ratio will be a bit off.
Old Jul 8, 2003 | 12:02 AM
ludis's Avatar
ludis
The deck height progression is 10.300, 10.310 (briefly), and then 10.322.
Old Jul 8, 2003 | 07:42 PM
codeman55's Avatar
codeman55
I'm running a set of '92 EFI heads and a '93 EFI intake on a '77 block with no problems.
Cody
Old Jul 8, 2003 | 08:44 PM
gabraham's Avatar
gabraham
Thanks everyone for your replies, helped a great deal. I will buy the short block tomorrow. Thanks
EvinrudeDude300
23
Mar 3, 2025 12:28 AM
DrZoom
Ford Truck Parts for Sale
Apr 3, 2016 02:20 PM
DrZoom
67
Oct 7, 2015 05:42 PM
Duthlerfordparts
Nov 4, 2003 05:03 AM
