The build begins!!! 1986 F250
#31
Well turns out that Mr. Hockey Puck lied about it being a 86 and turns out it's an 82. 82 was the last year for 400's, and after doing some research on the Vin, it originally came with a 400. With what the other members have said about it having the valve cover bolts and thermostat, it's a dead giveaway
#32
#33
C6: 17 trans pan bolts, pan resembles state of UTAH .. has a notch in it.
F100/350 & Bronco 351M/400 came with C6's, as did 351M in cars. Some cars with 400's also came with FMX's, has 14 trans pan bolt holes.
You said you decoded the VIN, originally came w/a 400 (1981/82 17 digit VIN, engine code is 8th digit: Z =400). But how do you know it's the original engine? It could have a swapped in 351M
Block casting number worthless for ID'ing engine size since 351M/400 use the same block. Measure the stroke: 351M = 3.50" 400 = 4.00"
#34
[QUOTE=NumberDummy;14341263]C6: 17 trans pan bolts, pan resembles state of UTAH .. has a notch in it.
Block casting number worthless for ID'ing engine size since 351M/400 use the same block. Measure the stroke: 351M = 3.50" 400 = 4.00"[/
#35
#36
#37
But the 351s didn't have the vertical thermostats, and the valve cover bolts are kind of dead giveaway don't ya think? Aren't there any numbers on the front of the block like what gm does?
#38
351C, 351M, or 400 Ford Engine - What is the difference? - FordMuscle
No, there are no GM-style IDs on these things.
#40
The 351M and 400 are both exactly alike in appearance on the outside, there is no way to tell by just looking at it if it's one or the other.
#42
On this subject, is there an easy way to measure the stroke without pulling the head? The only thing coming to my mind is to find a 6" depth ruler narrow enough to go through the spark plug opening. I say 6" to account for the combustion chamber and head thickness. I'm still not 100% sure that would be sufficient.
Also, about 15 or so posts ago SVT said that the vin code for the engine was, in fact, Z.
SVTdriver: you should confirm with maximum certainty that this engine is a 400. They are more desirable for use than the 351M.
#43
#44
8th digit is a Z. Which according to LMC's vin guide, it began it's life as a 400 F250. It was also built at the Twin Cities plant, so at least it hasn't ventured too far from its home
#45
I'm sorry. I know the stroke difference. What I meant was by visual inspection, the most reliable way to tell the difference is by checking the casting number on the crank.
