The build begins!!! 1986 F250
Definately a 351M or 400. A 302/351W has much narrower valve covers, and the spark plugs aren't nearly as shrouded.
Count again, but this time look in the upper corners. I can see 6 in 1 photo, 4 along the bottom, and the center 2 along the top, and I know there's 2 more in each corner.
Is a 351M not as good as a 351C or 351W? Will I not be able to get as much money for it if I were to sell it?
What about the tranny? Is it a C6?
Thanks for the help too!
A '97 F-350 would have had a Dana 60 front axle, so that's probably right. But it probably would have had a Sterling 10.25" rear axle rather than a Dana 70. That's a good axle too, but you might want to make sure you know what you actually have before you buy any parts for it.
The 351M is kind of a slouch in stock form, but responds well to upgrades. Cam, intake, headers will all benefit the engine. I advise you to pull the oil pan and check the crank. If there is a 400 crank, you will have a nice torque filled engine. Ultimately, the M/400 excells in torque, not horsepower.
As to the C6, mileage will be your main complaint. These are truly tough transmissions, and can take damn near anything you throw at them as long as you keep them cool.
C6 is the only auto trans that was used behind the 351M/400 in trucks. But yeah, the cutout on the rear pass side of the pan, right below the modulator valve, is a dead giveaway that it's a C6.
Side note, the 351M/400 uses the same bellhousing bolt pattern as the 460.
Ok well good...now I know what i'll be selling on CL.
Probably in about 2 weeks or so, i'll be removing the dash and then give everyone a How-to on removing the entire dash. What to look for, what not to do, etc.
I'm surprised with all of the guys out here doing restorations that no one has thought to do a walk-through with removing dashes? At least not that i've seen.
#29
Came across your Craigslist ad
1982 F250 400 Ford engine, complete with C6 110k miles.
