Anyone ever install a rear heat block off valve in the coolant hoses?
Old 05-01-2014, 02:03 PM
PPrash's Avatar
PPrash
PPrash is offline
My rear AC gets warmer after the rig warms up. I am going to check the blend door actuator but also was wondering if anyone puts a block valve in the coolants flow to the rear AC to shut it off in spring so as not to have that coolant heat even int he rear system during summer? I live in 100 degree & humid summers so it is of interest to get max cooling from AC system. If anyone has input or info on which line is the supply, done it, etc, please advise.
Old 05-03-2014, 12:15 AM
superdave02f552's Avatar
superdave02f552
superdave02f552 is offline
If it has all the original parts on it, it should be with the same shut off as the front. If the valve was ever replaced it could have been installed backwards which would allow the front to turn off but never the rear
Old 05-07-2014, 12:16 AM
superdave02f552
Just wondering if you found anything here?
Old 05-07-2014, 06:25 AM
PPrash's Avatar
PPrash
PPrash is offline
I did find that the original valve on the V10 does shut off both front and rear. I guess the diesel it only does front. My issue is there is no vacuum going to it to be shut off in RECIRC for some reason.
Old 05-07-2014, 06:26 AM
PPrash's Avatar
PPrash
PPrash is offline
PM me SuperDave if you want me to explain in more detail what I found. We can get on a quick call.
ewpierce
07-16-2018 12:48 PM
eXdiesel
07-12-2018 08:06 PM
genscripter
07-11-2014 01:48 AM
jayro88
08-04-2013 05:12 AM
jayro88
08-03-2013 07:06 PM
Quick Reply: Anyone ever install a rear heat block off valve in the coolant hoses?
