Things I've learned from my truck.
#31
#32
I learned that if you don't read and follow the instructions when you modify something, just modify it some more to make it work.
PO did a one piece, or solid side window conversion on my 56. I had to replace drivers side window broken in transit to Australia. Got one made here using it for a template. It never seemed to fill the channels properly. Due to my own stupid fault, I managed to break it again. To be sure I got the right size this time, I finally bit the bullet and got one sent by Midfifty. My mechanic could not get it to go in properly.
Ultimately we discovered that the PO had not followed the instructions correctly. He had not pulled out the embedded nuts that attach to a thin metal strip and hold the original side mirror in place in the door. These nuts pushed the channel back and made the window channel path perhaps 1/2 inch or so narrower. You pop the nuts out and the new mirror bracket is tapped to hold it in place. To fix the problem he got smaller side windows made!
Once the nuts were removed the window slid smoothly into place. Was a very expensive lesson for me.
#33
#34
#35
#37
Tom92F150
25
07-30-2017 04:42 PM
