Help with TS part on new truck?
Old 05-04-2014, 05:30 PM
aimcat's Avatar
aimcat
aimcat is offline
We just bought a new to us 02 f250 7.3, there was a card in the glove box that says TS performance. It says default code vdh4 and then 1-stock 2-hi idle 3-50 4-75 5-100 6-140
What is this?
Old 05-04-2014, 06:17 PM
Dan V's Avatar
Dan V
Dan V is offline
Is there rotary **** on the dash somewhere that you don't know what it is for? If so, then you have a TS performance chip installed.
Old 05-04-2014, 06:19 PM
aimcat's Avatar
aimcat
aimcat is offline
There is a turn dial at the fuse box. Is that it? There are no extra gauges or anything. It's a black **** with white line? If so what does this do and mean?
Old 05-04-2014, 07:31 PM
jps47's Avatar
jps47
jps47 is offline
yup that's the dial for the chip the defualt code is the pcm code for the truck or what pcm you have. So all the way to the left is stock all the way to the right is 140hp added, usually to much for stock sticks(injectors) so it rolls coal. High idle is good if your in cold climate as it will warm up faster
Old 05-04-2014, 07:50 PM
aimcat's Avatar
aimcat
aimcat is offline
Ok I see! Which is best for everyday driving (not towing) and best hp?
Old 05-04-2014, 08:35 PM
jps47's Avatar
jps47
jps47 is offline
I used 75 when I had the ts but I have a stick the chip will change shift points so find what you like. Look into getting egt gauge, black smoke means you sending more fuel than you can burn so egts will go up. Getting boost leaks sealed up will go along way as well for running any chip. More power means more stress on tranny to so keep that in mind. Just stick around here and you get more info than you can handle.
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
Generally the daily driving tunes are 65-80 hp tunes. I'd give both 3 and 4 a shot and see which you like better. Until you have at least a pyrometer installed, I'd avoid running it in the last two tunes.
If I were you, I would consider having the chip sent off to a tuner of choice for an update. Since you don't know how long it's been since they were written, we have assume they are older, earlier tunes. A lot has changed in the tuning world in the past couple years.
Old 05-04-2014, 08:42 PM
aimcat's Avatar
aimcat
aimcat is offline
Looks like it was done in 2013. Are these tuners bad for the engine or hard in it or transmission?
Are the 3 and 4 levels better on gas mileage than stock?
Old 05-04-2014, 08:54 PM
jps47's Avatar
jps47
jps47 is offline
all depends on your right foot
Old 05-04-2014, 08:57 PM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
Fuel mileage is largely dependent on driving style. You can observe an increase from stock if you drive conservatively. Most like the extra power, and drive more aggressively, which could show a reduction.
Are the bad or hard on engine and trans? If monitored properly, no. This is why everyone who really gets into tuning spends the money on gauges to monitor everything.
Old 05-05-2014, 07:58 AM
Tugly's Avatar
Tugly
Tugly is offline
My signature has links - the "Custom tunes" link has some useful information.
schlepprock250
05-29-2018 11:30 AM
jeffreyt
27
08-25-2013 10:11 AM
white Buffalo
09-13-2008 08:13 AM
powerstroke02
03-10-2008 04:44 AM
LEGENDS15
09-27-2004 09:42 AM
Quick Reply: Help with TS part on new truck?
