1953 F100 Not starting
Old 05-04-2014, 08:11 AM
48fordjeffie's Avatar
48fordjeffie
48fordjeffie is offline
Guys,
I went out with my daughter last night to get my wife a birthday card. When we got back to the truck, it cranked for about half a second, but immediately went to that hideous clicking sound. I had to call my seventeen your old son to come with my pickup to tow me home. Now, I know why I keep a chain in the truck. He wasn't too happy about towing me, I could see it in his face. After nearly yanking the bumper off the truck, I switched spots and I towed him. We got home ok, and no one was hurt. An cellphone on speaker is a big help while towing a rookie. We smelled a burning smell when we got home. I disconnected both posts on the battery.
The truck has most of it's original wiring, unfortunately, except the battery cables, starter solenoid, and anything else that can go wrong has been replaced. It is 6 volt with a Flathead V8.
Anyway, I just bought a new battery. I put a new starter solenoid in a few years back. I am wondering if it is the coil. Any thoughts here?
My father in law who helps me with this stuff will be home from Rhinebeck today. Thought I would get a head start.
Thanks,
Jeff
Old 05-04-2014, 08:42 AM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Clicking sound. Weak battery, bad battery cable connections, or bad starting relay. If it was dark when you drove it, perhaps the generator is not charging the battery. Perhaps the belt is slipping when the generator is under load. Are the replaced battery cables the big old heavy cables or something designed for 12V. Your six volt system is unforgiving of poor electrical connections, check them all. The coil would not cause the "clicking".
Old 05-04-2014, 03:32 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Ray is spot on. Start with the connections and wiring before launching into any parts replacement.
Old 05-04-2014, 10:13 PM
schoo's Avatar
schoo
schoo is offline
Ck the grounds all of them clean metal use dia elect or no-ox grease, rust or paint will not conduct elect
Old 05-05-2014, 07:57 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Sounds sorta lame but wack the starter a couple times with a hammer (like a nail hammer not something Large) and see if the starter drive is stuck in the flywheel. Very common on older vehicles.
Old 05-05-2014, 08:17 AM
48fordjeffie
Thumbs up
Thanks guys, I am leaning toward the grounds on the starter solenoid. I just talked to a mechanic, and he said a lot of old fords would start after cleaning the corrosion off of the solenoids connections. Something about copper and steel corroding fast.
I will let you know.
Jeff
Old 05-05-2014, 06:03 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Be sure to check where your battery cables go into their connectors, both cables and both ends. Look for corrosion then pull on them firmly.
Since you had it hooked up by a tow chain why didn't you try pull starting it? Or use jumper cables? Or did you just leave that part of the event out?
Battery cables are still my best guess.
72CC428
09-15-2012 07:17 AM
Bobtailfan
Electrical Systems/Wiring
06-21-2012 01:48 AM
skotyg
08-22-2011 12:21 PM
BlackLabel78
02-27-2010 08:01 AM
mike9762
02-03-2005 03:45 PM
Quick Reply: 1953 F100 Not starting
