Nifty Radiator set up for 6.0l from Flex-a-Lite
Hey guys i saw this advertisement on FB the other day, thought it was cool. Personally it's way over priced but it's a complete oil/tranny/radiator set up with two 15" fans and it also has a clutch fan emulator so no engine lights come on. The oil cooler can be used as any kind of radiator so you can either make the radiator bigger or the tranny cooler bigger or use it for oil etc. I can see it being useful if you have the $$$ for someone converting a gas SD to a cummins possibly.
Here is the link:
Flex-a-Lite Automotive Direct-fit Flex-a-fit® Aluminum Radiator and Electric Fans for
Here is the link:
I have seen the posted GCWR limit on the super duty efans years ago but I don't see them listed now despite no cfm or design change. If memory serves me right the max recommended GCWR was 18k lbs but I don't know what temps they had in mind at that rating. This is due to the reduced CFM the efan setup flows.(7.3l 6200cfm, 6.0l 6800cfm) Mark K has said the stock fan will move 20k cfm if need be.
If you don't tow much weight and keep an eye on your temps with real gauges I doubt you will have an issue with an efan.
Here is a old thread. https://www.ford-trucks.com/forums/5...an-clutch.html
silar
10-26-2015 01:19 PM
defiantoutlaw
05-19-2013 09:15 PM
AKFORD4x4
07-04-2008 06:47 PM
sdetweil
08-07-2005 06:39 PM
