Redhead gear question
I have not been able to locate the info I need after searching though countless of threads. I think I am just going to go with a redhead box right from the start. The question is my 74 f-100 with the 360 has the power assist system on it now and I am wondering if the current pump will work with the steering gear as far as the lines? I am changing everything over from a 78-79 f-150 with the T style system and ordering a redhead box for a 78-79 F-150. The only thing left is to figure out the lines before I start spending some cash. Any info would be great
Thanks
Jim
Thanks
Jim
I can't comment as to whether your existing hoses will work (my gut says no) but if you can't find a stock replacement you could always make custom cables to work with your pump and gearbox.
I went this route with my steering system (saginaw pump to '79 box):
Earl's Power Steering Hose - Free Shipping on All Orders @ JEGS
fittings and adapters to match:
Earl's Power Steering Adapter Fittings & Hose Ends - Free Shipping on All Orders @ JEGS
I have a couple pictures in my crew cab build thread if you want to see how it came out.
I would go with a 1978 or 79 F250 box. The install is easier and the box is much stronger, plus you will be able to use stock drag link from a 78/79 F250 and pitman arm. There are plenty of guys on here that have done the swap. You can reuse the pump but more than likely you will need new hoses.
79 Truckster
04-05-2018 11:26 AM
co425
04-08-2013 09:58 PM
tom1979
09-25-2007 08:02 PM
Rocket Doc
06-13-2007 10:09 AM
