Help: 295-65-18 Duratracs On 2" Leveled F-150 with 18x7.5" Stock Wheels?
Old 04-24-2014, 03:42 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
Question Help: 295-65-18 Duratracs On 2" Leveled F-150 with 18x7.5" Stock Wheels?
Just need to know from anybody that has or had this EXACT setup, is there any rubbing?
I have possession of my brother's truck while he's in Afghanistan, and I'm looking into putting bigger tires on for him. (His request.)
He wants as close to 34" that he can fit WITHOUT rubbing on stock wheels. I believe the 295-75R18 Duratracs are as close as we'll get.
He DOES want Duratracs. (His request.)
Truck is a 2004 STOCK F-150 w/5.4L, if does have a 2" leveling kit in it. (Block type)
Thanks for the help fellas!
Old 04-24-2014, 03:58 PM
motolorenzo's Avatar
motolorenzo
motolorenzo is offline
I have mine leveled (04 Lariat SCAB 4X4) with 305's on the same wheels. Works fine, no problems and looks much better than the 295's. Thats my 2 centavos. Renzo in Kau
Old 04-24-2014, 04:39 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
With stock 18x7.5" wheels?
What kind of tires? One of the reason I'm looking for such a specific tire is Duratracs have very wide sidewalls.
Old 04-24-2014, 06:26 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
Bumpity...
Old 04-25-2014, 08:14 AM
twfish's Avatar
twfish
twfish is offline
Usually what causes your rubbing is offset of the rim. A 305 is a 10 inch wide tire and I imagine putting that on the rim would cause it not to be covered under warranty. 295 will probably be fine. Thesed trucks can run 35 without rubbing
Old 04-26-2014, 12:22 AM
motolorenzo
305's
What I'm running are BFG 305-65-18 AT, TA, KO, Load Range E, 3 Ply Side Wall, Aggresive Tread, rated at 65 psi.. When empty I run 45 psi., When heavily loaded with often 4000 lbs. in the bed I run 65 psi.. They are quiet for the tread design and ride good. I rotate at 5000 miles. I got on to these after the last set of ***** BFG OEM tires rated at 35 psi with 2 ply side walls. I had to order the set thru COSTCO because all the other dealers were over $200 more. Thru COSTO out the door the set was $1417.00 all included. I haul some heavy loads and some heavy boats quite often. You have more to choose from on the mainland and certainly better prices, but I'm happy with these. Thats the story. Renzo in Kau, Big Island, Hawaii
Old 04-26-2014, 06:31 AM
tjcprop's Avatar
tjcprop
tjcprop is offline
I have used a 305/60 18 Pro Comp Xtreme MT which is more aggresive looking that the Dura Trac without an issue. More costly of a tire but a true 10ply.
Old 05-02-2014, 02:02 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
Fits like a charm, and looks great! Perfect! (Except for price.)
Before:
After:
Old 05-02-2014, 02:04 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
Old 05-02-2014, 06:45 PM
tjcprop's Avatar
tjcprop
tjcprop is offline
That one picture of your finger in thread. Imagine the depth of thread being two fingers deep. That is Pro Comp Xtreme MTS
Old 05-02-2014, 07:18 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
First....Bull chit. Seen 'em. No. From Pro Comps website, other than the 37" tires, the deepest tread they have is 20/32. Pro Comp Xtreme M/T 2 Radial - Pro Comp Xtreme M/T 2 Radial - Pro Comp Tires - Tires - by Pro Comp The 295-65R18 Duratracs are 18/32.
Second... Pro Comps wear out to quickly. They have too soft a compound.
Lastly....do you sell them or something? Your Pro Comps have nothing to do with this thread, nothing whatsoever.
So why a
re you posting twice about Pro Comps??? And not even the right size?
Old 05-02-2014, 07:56 PM
tjcprop's Avatar
tjcprop
tjcprop is offline
No I don't sell Pro Comp. I drive on good tires than wear, handle and look great. Living in Canada with weather from +40C to -45C and 250cm plus of snow. I rely on my tires for snow plowing and towing in summer. There is a reason why the Xtreme MTS are worth more??
Old 05-03-2014, 02:42 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
Originally Posted by twfish
Normally is the time I step in and calm things down but seeing your a post master I dont think you need told. Hes gotten on my nerves too but we dont want to push users away
Normally.... I'd be right there with you.
But....as I clearly stated in the first post....this was a fitment question regarding one tire and one wheel. Not looking for other suggestions. And when you are posting multiple times in more than one thread, and posting NOTHING HELPFUL or even relevant to the thread(S)....you're gonna get called out.
Old 05-03-2014, 04:44 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Ease up on the language used when ya disagree with others, people.
I'm a nice guy and I prefer to give lots of leeway, but if I have to clean up the thread again due to language I'll be forced to take my Mr. Hyde potion.
Stewart
Old 05-03-2014, 04:54 PM
twfish's Avatar
twfish
twfish is offline
I agree, but he is still pretty new too the site. Im really not trying to stick up for him, I just dont want new users to see this and think that everyone is going to call them out
BlownGP
62
03-10-2016 05:55 PM
Tugly
09-09-2012 01:14 PM
RoadRaceIt
02-14-2008 11:43 AM
cehowardf150
2004 - 2008 F150
09-28-2006 03:01 PM
GLankford
2004 - 2008 F150
04-23-2004 09:11 AM
Quick Reply: Help: 295-65-18 Duratracs On 2" Leveled F-150 with 18x7.5" Stock Wheels?
