1959 F100 Ignition lock replacement
Old 04-29-2014, 02:37 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
78 & 87 Super Cab is offline
I need to replace the ignition lock cylinder in My 1959 F100, How do I do this?
Old 04-29-2014, 04:29 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
See the plate that says start on off? Push the ignition from behind toward the cabin and twist the plate on the outside counterclockwise 1/4 turn and the ignition will pull out from under the dash.
Old 04-29-2014, 07:03 PM
78 & 87 Super Cab
OOPS,.I worded the post wrong, sorry. I have the switch out of the dash, I need to know how to get the old lock out,and install the new lock cylinder
Old 04-29-2014, 07:13 PM
Damifiknow's Avatar
Damifiknow
I don't remember Sorry. Someone will chime in soon.
Old 04-29-2014, 07:52 PM
spurredon's Avatar
spurredon
spurredon is offline
If my foggy memory serves me at all, I think there is a small hole in which you insert a small drill bit or similar to release the lock cylinder from the switch.
GMbusa
12-08-2015 10:21 PM
Lascar
02-15-2015 09:07 PM
EL_Musico
10-04-2011 12:18 AM
Jackhammer
1983 - 2012 Ranger & B-Series
04-09-2006 12:19 PM
Quick Reply: 1959 F100 Ignition lock replacement
