alt question
Old Jul 5, 2003 | 03:00 PM
shagg's Avatar
shagg
alt question
i have a alt i`d like to install in a 51 ford truck but dont know how to wire it and most people i`ve asked hav`nt even seen one the truck has no wiring at all and i`ve allready set in a perkins 354 turbo diesel so i have to make everything ,, the alt is a ford/ leece-neville 165 amp it was rebuild for a squad but was never picked up anyone know how these wire or have any info? thanks for the help!!!!!!
Old Jul 5, 2003 | 03:15 PM
Mil1ion's Avatar
Mil1ion
alt question
Does this help?
Old Jul 5, 2003 | 07:59 PM
voltsnxs's Avatar
voltsnxs
alt question
Piece of cake. Here's what ya need to do.
You need to buy an inexpencive alt and a regulor. Ford of corse.
the alt runs aroug 24 bucks common on 1970-78 models. Hook up the cable from the pos side of the battery to the big pos on the alt. 8 AWG Then you'll need to run a wire from the field side of the reg to the field side on your alt. 12 awg. That's it for the alt.
Now run a wire from the pos side of the batery to the I on the reg 12 awg. now ground it real good. Make sure it is grounded before you start the truck. Other wise on these cheap solid state regs they blow out. I think I covered all the wires. It's pretty simple but when you get old things have a way of getting lost.
Old Jul 5, 2003 | 08:18 PM
Franklin2's Avatar
Franklin2
alt question
I would not run the "I" terminal to the battery positive. This will run the battery down. Here's a diagram if you want to run a voltmeter or amp guage. The "I" terminal is only used if you want an "idiot" light, and the whole set-up is wired a little different.
Of course all this is for a normal truck alternator. I don't know if the one you have might have a different wiring set-up.
Here's the wiring if you want an idiot light in the dash.
Old Jul 5, 2003 | 09:06 PM
shagg's Avatar
shagg
alt question
thanks for all the help guys but this alt is a weird set up it has 2 big posts on the back that says caution observe polarity and has a pos and neg on them ..on top it says leece-neville 14.25 reg and a small post with no markings then beside that is 3 screw holes looking from the back the one left has a tab screwed to it the middle and right one is empty hope that helps the tag reads service parts type no 7706ja under it is 14 volts under that date code9340 left tag reads unit model number a001090754 under that amps 165 under that cleveland ohio a prestolite electric business in the middle says ac ac ac neg and pos symbols sorry for all the details thought it might help
Old Jul 6, 2003 | 01:39 AM
savagetek's Avatar
savagetek
alt question
What year was the amp mfg'd? If it's relatively new, it's probably internally regulated. Therefore, no external, remote VR. In this case, the diagrams above won't help.
Just did a quick web search using your details and found the Prestolite Web Site and Leece-Neville reference data. Probably the best start come Monday would be to call the Leece-Neville Support hotline -- as referenced at:
www.prestolite.com/pgs_tech/trouble_shoot_1.html
"...Just call 1-800-346-8093. Knowledgeable, experienced technical representatives are ready to help you keep your operation running smoothly...."
Old Jul 6, 2003 | 08:59 AM
shagg's Avatar
shagg
alt question
savagetek thanks very much!!! thats the bird i was looking for,, and your right on the internal reg its preset to 14.25 volts i emailed them for a wiring chart , so just need to wait on a reply before trying to call ,,, thanks again!!!!!!!!!!!!!!!!!!!! you were a BIG help
Old Jul 7, 2003 | 08:14 AM
shagg's Avatar
shagg
alt question
hello guys!!!!! well prestolite wrote me back on wiring the leece-neville/ prestolite alt 165 amp the kind off ems units,,, on the back there is a pos and neg posts that are marked they said hook those 2 up thats all there is to it it is self exciting and self regulating thought that info might be handy to someone
Old Jul 7, 2003 | 04:45 PM
shagg's Avatar
shagg
alt question
ok didnt work some might be self exciting but mine didnt work ,, i hooked it up like he said then i added a keyed hot to the small post on top works great self reg working fine too
9d4
Jun 16, 2008 05:55 PM
Pocca
Electrical Systems/Wiring
Jul 25, 2007 01:31 PM
dv_shane
Oct 2, 2006 10:51 PM
kevcarlson
Sep 21, 2006 09:34 PM
baitmaster
13
Feb 12, 2005 05:40 PM
