Passenger side exhaust leak
Old 08-27-2013, 12:13 PM
Jamesstafford74's Avatar
Jamesstafford74
Jamesstafford74 is offline
I have one of those loud, annoying, ticking style exhaust leaks on passenger side. Manifold was replaced two years ago so I'm hopeful that its a donut gasket. Went to parts store and they couldn't find one! What am I missing? How is this connection made and how do I know if it leaks, or is the manifold again? Thanks.
Old 09-09-2013, 09:07 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
There is no gasket there its just a flanged metal on metal fitting, Look very closely for broken studs or a cracked manifold..
Old 09-28-2013, 03:59 PM
jetdoc's Avatar
jetdoc
jetdoc is offline
I thought I had a exhaust leak on my Cobra....Intermittant ticking noise, drove me nuts. Checked the exhaust and all tight. Ended up being a spark plug had come loose.
Old 04-14-2014, 04:12 PM
jackone's Avatar
jackone
jackone is offline
I have had this for a while now. As engine warms up it goes away so I have been living with this. But it is horrible. Sounds like a junk truck at start up. Looked close at manifold and cannot find anything. Have not changed plugs yet might give that a try to see if that works. Any one else have a clue on this?
Old 04-28-2014, 07:56 PM
Robertf2's Avatar
Robertf2
Robertf2 is offline
I have the same problem on the same side on my truck. My truck used MLS type exhaust manifold gaskets. My truck makes a whirring (?) sound on startup and tip in.I also had to replace the gasket on the drivers side. I picked up a Fel Pro gasket set that had the fiber and steel (or aluminum) laminated construction.
Old 04-28-2014, 08:02 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
What year truck and how many miles?
I called ford on my 08 with 80k miles on it that needed its second set of manifolds. I screamed and yelled and finally got them to cover 60% of the repair. Just an idea.
Old 04-29-2014, 11:01 AM
jackone's Avatar
jackone
jackone is offline
I am just over 100k miles. Doesn't sound like an easy, straight forward solution. Headers usually are no better. Different studs maybe? Gaskets that have worked? Any help would be great.
NM33013
01-29-2019 09:34 AM
Tod1985F250
15
04-18-2013 07:03 AM
kfnpemai
1997 - 2003 F150
12-30-2005 11:26 PM
armcan
Bronco II
12-09-2003 11:46 PM
James Hewett
Modular V8 (4.6L, 5.4L)
08-02-2003 01:38 AM
Quick Reply: Passenger side exhaust leak
