Power Steering Pump Chirps 99 Van
Old 04-25-2014, 05:54 PM
Fard
Fard is offline
Fard is starting off with a positive reputation.
I have a chirping noise with new pump I installed last summer it was pretty much gone up until recently and just started up again. Could it be I need new pully, my belt is good or possible didn't seat the old pulley all the way snug? I also have the steering pulling hard then letting go, but I think I have found that to be the steering shaft universal joint and am hitting it with Liquid Wrench and it seems to be loosening up
5.4L
264,000 mileorenos man
Old 04-26-2014, 02:11 AM
thzpcs
thzpcs is offline
thzpcs is gaining momentum as a positive member of FTE.
Try spraying a bit of anti-squeak on the belt. Although, that pulling and such seems like there might be an issue with the pump itself.
Old 04-28-2014, 11:32 AM
Fard
Fard is offline
That's what I was wondering but it's a new pump? So I found elsewhere on here the same symptom and they said try the universal joint, I think that has improved some but who knows it could start at any time I spose. I'll hit that w/some belt squeak,it's due for a new belt anyway, maybe I should just go ahead and through one on. THX
Old 04-28-2014, 07:43 PM
dkf's Avatar
dkf
dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
A belt chirp or squeak is often caused by a misalignment of a pulley or something pushing the belt off track. A tensioner or idler pulley can throw it off enough to make a chirp also. Doesn't matter if the part is new, if it not aligned right it can cause a chirp and excessive belt wear.
I ran into that with a vehicle that had wear on the idler pulley. It was the weekend and I did not feel like running to get a part so I made a fixture and turned the OD of the pulley on the lathe to true it up. That fixed the chirping belt.
Old 05-01-2014, 08:19 AM
Fard
Fard is offline
I wondered if that could be it, I don't have a lathe, maybe I will get down there, It's a PITA with a straight edge and see what I can see. I could just get a new pulley, actually I read somewhere that you are supposed to replace that pulley at some interval. THX
BillyLeach84
02-03-2017 07:51 PM
Mikelangevin
1999 to 2016 Super Duty
04-10-2016 12:09 PM
Bob Montoya
2004 - 2008 F150
01-08-2016 07:38 AM
tsuydan
02-22-2015 08:47 PM
FDNY13
11-11-2013 05:55 PM
Quick Reply: Power Steering Pump Chirps 99 Van
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
