Extended Warranty ending soon, What to check?
My extended factory warranty ends next week. I had the 7 year 100K premium warranty and thankfully never needed it. The only issues I had the dealer fix so far was the transmission at 57K for the shuttering TSB. The only issue I have now is that one of the rear window vent motors clicks when it closes. The A/C vent motor has made a few weird noises when switching modes but other than that all is good. Because of fuel costs, I picked up a smaller and cheaper car to wear out so I haven't driven the expedition as much as I planned on.
I haven't changed the spark plugs yet, but it sounds like no warranty will cover breakage anyway, so I'll either do it myself or have a trusted mechanic do it for far less. I have access to a scanner, but I'm not sure if it will show any ignition coil problems that could be developing.
Any advice on things to check before my warranty expires?Thanks
The shudder is a misfire and will show up in the data log as a potential pending code - it is recorded as a misfire and added to the log for comparison to the limits to set the code. The shudder from a misfire doesn't usually show itself when you let off the gas, it happens while you are on the gas under slight load.
Optimistic Paranoid
General Automotive Discussion
16
10-16-2015 05:01 AM
doc4bax
1997-2006 Expedition & Navigator
06-22-2005 07:27 AM
