Need info on 292 rear motor mount bolt
Old 04-21-2014, 11:21 PM
chetspencer's Avatar
chetspencer
chetspencer is offline
So I just noticed that I'm missing the drivers side rear motor (bellhousing) mount bolt and lower motor mount. I can't find any info searching the internets. I see that Sac Vintage has the lower mount for cheap, but no bolt. Also I noticed the passenger side has a locknut, was that added?
Thanks in advance!
Old 04-22-2014, 02:38 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Also I noticed the passenger side has a locknut, was that added? No.
Both sides are supposed to have the locknut.
See parts catalog pic at bottom of page.
34451-S8 .. Locknut / 9/16" -18 / Obsolete
GREEN SALES CO. in Cincinnati OH has 15 = 800-543-4959.
353426-S8 .. Bolt-Use with M/T / 9/16" -18 x 3 1/8."
GREEN SALES has 10.
353561-S8 .. Bolt-Use with A/T / 9/16" -12 x 2 7/8."
Similar bolts and the locknut can be bought from any hardware store.
Old 04-22-2014, 02:44 PM
cyclone-429's Avatar
cyclone-429
cyclone-429 is offline
These bolts can be bought from any hardware store.
Make sure you use grade 8 bolts only!
Old 04-22-2014, 07:45 PM
chetspencer
Thank you Mr Number Dummy!! Looks like I'm missing 6A027, 6A021, 353426-S and 34451-S
Old 04-23-2014, 01:14 AM
NumberDummy
Thank you Mr Number Dummy!! Looks like I'm missing 6A027, 6A021, 353426-S8 and 34451-S8
No such part number as 6A021. 6A061 is the rubber insulator below the cross member...see parts catalog pic.
B3TZ-6A027-A .. Spacer ~ 1957/60 F100/600 272/292 / Obsolete
GREEN SALES CO. in Cincinnati OH has 55 = 800-543-4959.
COTT-6A061-B (replaced B3TZ-6A061-B) .. Rubber Insulator ~ 1957/60 F100/600 272/292 & 1961/64 F100/250 292 4WD / Obsolete
GREEN SALES has 285.
Green Sales also has the bolts and locknuts, see post 2.
Parts catalog illustrations of standard (aka hardware) parts may not show the complete suffix. The text section of the catalog is necessary to verify.
As you can see, I added the 8 to complete the suffix.
Old 04-23-2014, 07:39 PM
chetspencer
Thank you again, your a National Treasure.
ftrk66
07-02-2015 06:31 AM
oscajo
08-07-2013 07:51 AM
AmericanROCKBREAD!
06-16-2011 08:45 PM
itsmywifestruck
03-14-2009 07:24 PM
mauger
07-28-2008 07:00 PM
Quick Reply: Need info on 292 rear motor mount bolt
