HOWTO - Add LED Lights
Old 01-21-2018, 07:39 PM
robinc2's Avatar
robinc2
robinc2 is offline
LED answer
i found a website that sells LED bulbs that fit the conventional incandescent bulb sockets making the upgrade awesome.
here it is:
JDM ASTAR Auto LED Bulbs,LED Headlight,Fog Lamps & Turn Signal Brake Tail Light
i hope this helps.
Chris
  #77
Old 09-22-2019, 02:52 PM
Jghake's Avatar
Jghake
Jghake is offline
I replaced the old bulb in my under hood light with
this this
and it works great and is extremely bright.
BA15D seems to be the bulbs size.
  #78
Old 09-25-2019, 12:50 PM
The_Scatch's Avatar
The_Scatch
The_Scatch is offline
I think I almost stopped reading this thread when it said, white LED's don't produce red light, only white....
I think we learned in the early years of school white is the culmination of all wavelengths of color, and black being the absence of all. If you see white light, there is some sort of simulated red frequency present. LED's simulate white light with Red Green and Blue outputs. Or they use a short wavelength LEDs with a phosphor coating (notice your flash light LEDs are yellow) that coating converts the blue light to "white", this is an effect Sir Isaac Newton discovered a long time ago. The latter of these two options may give you a washout affect. If you have a multi led bulb like the former you will not have this issue.
Wow this guys a douche...
No I didn't actually almost stopped reading, just wanted to hook you in because I like science lol, and some people like me find the why interesting.
  #79
Old 09-25-2019, 01:03 PM
The_Scatch's Avatar
The_Scatch
I did want to add for those out There I have been using these LED in the cab where 194's are called out and they work very well. They are the size of the old bulbs so no worry about fitment issues.
  #80
Old 09-26-2019, 05:15 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,101 Likes on 1,790 Posts
As you pointed out you get wash out if you use a white bulb to shine thru a red or yellow lens and why you want to use the same color bulb behind a colored lens.
Right now I only have green LED's in the gauge cluster without the colored lens and I like it so far in testing in the garage.
Before I add any LED's to the outside I want to get all lights working with normal bulbs, nothing worked on this truck when I got it but I have also moved the whole wiring harness from my parts truck to this one.
Dave ----
  #81
Old 09-26-2019, 09:12 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Same here, removed color filters, installed low profile 5 chip T10 LED bulbs in blue gives a factory new blue hue. the hvac panel you have to run blue as it has a blue filter sandwiched between the layers.
  #82
Old 09-27-2019, 05:20 AM
FuzzFace2's Avatar
FuzzFace2
I left the normal bulbs in the HVAC & wiper / head light switch areas as I don't need them as bright as the gauges to make sure all is good.
Dave ----
  #83
Old 09-27-2019, 09:41 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Dave ----
Same thing I did. Only thing is I am trying to find a dash bezel that is damaged but the headlight/wiper indicator is in good shape mine the paint is scraped off so you don't see the headlight and wiper logo that easily. Figured it would be easier to melt the plastic rivet off and CA glue a replacement in that's in better shape.
  #84
Old 10-31-2021, 05:56 PM
eriksf250's Avatar
eriksf250
eriksf250 is offline
How many led bulbs would I need to replace all the lights in the dash and hvac controls on my 86?
  #85
Old 10-31-2021, 07:35 PM
FuzzFace2's Avatar
FuzzFace2
Thought I had a picture of the back of the cluster to count the bulb sockets but I dont sorry.
I did not use LED in the HVAC, headlight / wiper or radio.just the cluster.
This weekend I can check a 2nd cluster I have to see.
Dave ----
The following users liked this post:
  #86
Old 11-01-2021, 12:25 AM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Going from memory I want to say I used 5 in the cluster for illumination for the gauges, 5 in the indicator lights at the top for turn, high beam, brake, and seatbelt. There is 1 in the headlight/wiper switch bezel. For the climate control I want to say there was 2 there and 1 for the ash tray. There is also 1 for the radio as well but that bulb is quite hard to find I found some online and been meaning to switch the one I used out for this other one I found that has more chips which I hope will get rid of the hot spot on one side of the radio dial.
Photos of my conversion I done years ago. Everything is LED using T10 wedge base bulbs for the most part minus the radio which is using a micro wedge base bulb.
The following 2 users liked this post by Rusty_S:
  #87
Old 11-01-2021, 07:05 AM
eriksf250's Avatar
eriksf250
Thank you Fuzzface and Rusty, I appreciate it. Rusty I like the look of those color LEDs, are they ice blue colored?
  #88
Old 11-01-2021, 08:10 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
No they are the standard blue. The Ice blue is a even lighter blue color which I didnt want. Many people have commented when I did mine that the blue is very spot on to how these trucks looked color wise when new.
iRockFosgate
41
11-24-2017 05:37 PM
abe
06-24-2016 10:12 PM
wrhinehart
24
11-10-2015 06:15 AM
Supercab
08-17-2006 06:00 AM
yyz87
Appearance & Dress-Up
08-07-2003 04:35 PM
Quick Reply: HOWTO - Add LED Lights
