ignition help
Old Apr 21, 2014 | 11:10 AM
MJ76's Avatar
MJ76
ignition help
Just about finished with my 390 build. Now I need to decide on a distributor.
This is what my build is 390, 40 over, comp 268h cam, edelbrock performer and holley truck avenger 670 carb. So I thinking msd 8595 ready-to-run and a 6a or a D.U.I advantage? Do I need to spend the money on these higher end distributors? Or go with some thing else?
Old Apr 21, 2014 | 12:06 PM
69cj's Avatar
69cj
Less than 100 bucks for a Pertronix and it fits in your stock dizzy. Another 35 for their flame thrower coil.
Old Apr 23, 2014 | 05:45 AM
yetiman38237's Avatar
yetiman38237
You can get a late model FE distributor and do either duraspark or gm module as well. I am still running stock coil and points with my setup......haven't decided which way to go....
Old Apr 25, 2014 | 09:34 AM
KO1960's Avatar
KO1960
X2 on the Pertronix. Stock look and smaller than hei units. You can also reinstall points if there is a problem. No problems with mine after 5+ years.
Old Apr 25, 2014 | 04:21 PM
jowilker's Avatar
jowilker
Petronix or Duraspark are good choices, my choice Petronix.
John
Old Apr 26, 2014 | 12:19 AM
MJ76's Avatar
MJ76
Thanks all the information. This motor is going in a 76 highboy and is going to pull a 21' Willie jet boat. So is there a benefit with the msd or a better distributor then a stock one. This is my first build and the truck is not my primary tow rig. But I want a classic Ford that can pull the hills in the great n.w. Thanks for the replys
Old Apr 26, 2014 | 04:59 AM
jowilker's Avatar
jowilker
No, The 76 should have duraspark. You don't need hi performance parts for pulling. Headers for better ail flow would be good.
John
Old May 3, 2014 | 07:11 AM
smoothcriminal69's Avatar
smoothcriminal69
The HEI swap is super easy but it is bigger, the petronix is a great easy kit also. The HEI kits on eBay come with a new coil,cap, and wires for 100$, it was to hard to beat for me.
FordEdselFanatic
Feb 28, 2009 12:13 PM
workingdog
Dec 23, 2005 01:42 PM
BigBrownTruck
Aug 10, 2004 11:16 AM
76 F150 Ranger XLT
Jul 30, 2004 09:37 AM
fordeverpower
23
Oct 17, 2003 02:53 PM
