High rise and spacer?
The larger the volume inside the intake, the weaker the engine will be a low rpms. If you are setting this engine up for high rpms, along with a stall convertor in a auto tranny, and higher numbered gears in the rearend, that will be ok. If you are leaving everything else stock, it's not going to run very well.
wcpc4
07-11-2016 08:19 AM
LARIAT 85
05-21-2008 04:17 PM
