Intake manifold port question?
Old 04-17-2014, 10:15 AM
Wolffman's Avatar
Wolffman
Wolffman is offline
Can anyone tell me what the port is that's circled on the intake manifold?
[IMG][/IMG]
Old 04-17-2014, 10:22 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
That's the exhaust cross over passage. It's function is to help warm the carb base when the engine is cold so that the fuel vaporizes quicker. In some applications it also has a loop in it that helps operate the automatic choke.
If you're running headers then the port becomes inoperative because the headers delete the exhaust heat riser valve. This is the thermostatic valve in the exhaust manifold that directs the exhust flow through the passage.
Old 04-17-2014, 10:23 AM
Wolffman's Avatar
Wolffman
Wolffman is offline
Thanks for the quick reply.. So if i had an intake manifold that did NOT have that port on it then it wouldn't cause any problems?
Old 04-17-2014, 10:28 AM
Wolffman's Avatar
Wolffman
Wolffman is offline
Old 04-17-2014, 10:34 AM
mikeo0o0o0's Avatar
mikeo0o0o0
No, as long as the heat riser valve is disabled (if you're still running exhaust manifolds). That's a valve that is between the driver's side exhaust manifold and the exhaust pipe. When the engine is cold, the valve is shut and directs the exhaust flow from the driver's side head through the exhaust crossover and dumps into the passenger side manifold.
In reality, most of these valves are already seized, usually in the open position.
If you're running headers, the valve has already been discarded..
A lot of high performance manifolds delete the cross over because one, most engines are running headers and two they want to keep as much heat as possible away from the carb for a denser intake charge.
This is an FE but the valve, with minor variations, is the same on most Ford engines.
Old 04-17-2014, 10:38 AM
Wolffman's Avatar
Wolffman
Wolffman is offline
Well I don't see anything on my exhaust manifolds. I'm in the process of putting on some gt40p's and noticed that I didn't have that port on my intake manifold. Thanks!!!
Old 04-17-2014, 10:40 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, shouldn't be a problem.
Old 04-17-2014, 11:01 AM
turbohunter's Avatar
turbohunter
turbohunter is offline
Wolffman
Experience comment.
On my build I have a manifold with the ports built in ( Ed Performer). I blocked off the ports with some stainless.
I went through the brain games of "should I keep it for drivability, or get rid of it for performance".
It actually doesn't make a bit of difference to the cold drivability of the truck if you have a good running choke. I live in SoCal but I have talked to guys that live in the frozen north and they have no problems either.
So as Mike said, "fear not", it seems to me that it's an old tech fix that may have worked at the time but not needed anymore (as long as you make sure the valve is disabled or frozen open).
Old 04-17-2014, 11:33 AM
Wolffman's Avatar
Wolffman
Wolffman is offline
Originally Posted by turbohunter
Wolffman
Experience comment.
I don't even have a valve on the truck so hopefully it's just a port that goes to nothing
Old 04-17-2014, 11:40 AM
turbohunter
Then no worries at all
Old 04-17-2014, 01:17 PM
Wolffman's Avatar
Wolffman
Wolffman is offline
Thanks guys!
Lax
02-28-2017 11:56 AM
PanchoPancha
02-25-2017 11:51 AM
Henry Carter
08-01-2010 07:15 AM
aunchman
10-06-2003 12:31 PM
Quick Reply: Intake manifold port question?
