4" lift with 33's??
4" lift with 33's??
A buddy of mine used to run the 4" Pro Comp on his PSD CC SB with 35/12.5 X-terrains.....he had to remove the air dam (could have just trimmed it) to be able to clear the tires and they would rub on the inner plastic fender well. So, you'd be able to clear the 33s w/o rubbing.
All depends on your personal preference.
I think what makes a 4" lift and 33s look small is the size of the tire itself compared to the size of the truck, not the amount of space left in the wheel well..........I like the look of 35s on a 6" lift.
Hope this helps.
Hope this helps.
turnkyle
03-30-2011 08:36 AM
