I have DashCommand. It's good, but it's not awesome. I can't seem to get the Transmission temperature to display, or the Coolant Temp. Same result for EngineLink.
For a diesel, those are 2 very crucial numbers that I can't get.
I'm running Dash Command on my Iphone. Great app that displays alot of info. I have no problem with any of the temps (engine and trans no issues)! I'm using a WiFi dongle. I have about $40 in it not including the phone! I highly recommend it.
I use the iTSX from SCT with my iPad 4. It works as a tuner and it can display up to 6 different measurements at a time (and there are about 20 different measurements that you can choose from, and change them whenever you want).
Huh. I wonder if I have a bad sensor in my truck then.
Are you getting coolant temperature too?
Yep, engine and trans temp. the only thing it doesn`t show me is fuel remaining in tank. no big deal, but it would be nice to know exactly how many gallons remaining! otherwise it all works great!
