"Red Green" My 1976 F250 Super Cab IDI Swap
#76
#77
It helps, though honestly if you look I have to deal with a dirt floor, whoever built this I'mean guessing didn't want to pay for a permit to build a "Permanent Structure" so they left it dirt and only oiled it. So sadly it's pretty hard to work with engine hoists and the lot, I usually have to move the vehicle as opposed to the engine, but it works. In winter it soaks up all the moisture from outside and can turn into a real mess... have more outside than inside because of it. One day I'll have concrete
#78
Late to posting
Still waiting on everything for these Motor Mounts to be finalized before pulling the trigger to having several sets made, so far they are turning out well!
So little update, finally recieved my R&D RD-90 Pump and Stage 1 Injectors from Justin at R&D IDI performance, I'll finally be able to close up my 6.9L that has been sitting over at the Machine Shop and get it ready to transplant, so far so good.
Hopefully soon I will be able to post more on the Hydroboost and Hydro Clutch setup I built for this swap, also need to track down a M/T Steering Column still and a few other things, sadly the Local Scrapyards are devoid of Dentsides lately.
#79
#80
Best way to describe it is I'm between Sacramento and Stockton, But in the Sierra Foothills, where are you located? I Could ve interested in your Motor Mounts and Mount Plates for sure.
#81
#84
thanks
#85
hope that helps.
#86
#87
Found the spindles fit and match the same dimenssions of the 70s I-beams perfectly, but am currently figuring out what I will be using as a steering Box... between a 1977.5-1979 f250 4x4 box or a 1980-1999 F250/350 4x4 box. Been busy sourcing a few harder to find parts rught now and have finalized the 3rd prototype of my 2wd mounts so after they are cut I will be fabricating them and moing on finally.
#88
https://www.ford-trucks.com/forums/1...-and-pics.html
#89
Sure if you wouldn't mind that would be awesome and greatly appreciated. Thanks for the help.
#90
The post just above your response will actually cover your 4x4 mounts, just started in on the mount plates last night, tonight I will be be updating more. The link will send you to the right place.
