Just checked the paper work. Yes the warranty plate number matches. But I'm missing the certification label. The entire truck was repainted a couple years back. Assuming because it rains here more often then not, I guess it wasn't worth saving to them.
Thank you so much for your help!
Assuming because it rains here more often then not, I guess it wasn't worth saving to them. Take a close look, it may have been painted over.
I've been to Hawaii 8 times, it seems to rain every Wednesday on Oahu. It's EZ to spot the tourists, they're the ones with umbrellas!
martiauto.com (located NW of Phoenix in El Mirage AZ) has ALL the original 1967/79 FoMoCo records.
Has reproduced the Warranty Plate, the special rivets used to attach it to the door, Certification Label, and can also supply your trucks original build sheet.
