"Got her dialed in On the way home, the check engine light came on and I lost throttle response. She wouldn't shut off, just kept coasting with the engine on. Shifted into neutral and back into drive and regained pedal power. Happened 3 times, any idea what would cause that? A sensor or plug?"
This was what I meant... Been doing some massive catching up around here and may have misread this... lol
Some have found the bolt through the middle loose and then if you look at the pic again you'll see a rub mark on the valve cover right below it. Some have found wires on the bottom of the bundle worn through right there
Thank you AllaboutMPG, I'm going to save that pic for my electrician. What's the best solution? Replace wire loom section with OEM or from scratch?
The wires if damaged have usually just rubbed through the insulation. Liquid electrical tape or tape to repair insulation then something heavier to prevent future rubbing
What do you mean by was The truck is BETTER than ever (not train horns) put in holes for clearance lights, I put in holes for trumpets Oh, I need one more hole for the thru the roof NMO antenna mount
and I found a nice video on how to install the TS Performance Chip;
