06 f250 4x4 won't work
I have a 06 with a 5.4 and the 4x4 will not work . the switch on the dash when rotated the light on the dash dosen't come on but I hear the transfer case switches "clicking" when I go from 4 wheel to 2 wheel ? I checked the vacume on the hubs and up to the canister and all is good ? is this a switch problem ?? any help is great , Thanks...
time to check the switch I think. Verify it has power since you have no light.
Additonally switch to 4 hi and leave the truck in park.
Get under the truck and see if the front drive shaft is locked in. If locked then at least the front hubs have engaged.
If engaged another check is to put in the drive with 4hi selected. Very slowly try to make a turn to verify whether or not 4hi is engaged. It should not want to turn worth a darn.
Note this is hard on the drive line so you don't want to do this very much Just a few feet.
