hellwig helper spring?
I installed the SES kit for my Van ...It took me about 1 hr. in my driveway....works real good.....Suspension Enhancement System Lookup - Timbren Industries
Timbren are a great accessory
I installed them on my '92 E350 cube van about 8 months ago, took the sagging rear end out (158"wb) and took the body roll totally out.
You remove the OEM bump stop on the frame, and install the rubber "spring" in to the existing location, and install the flat plate with the U-bolts on the axle to support the bottom on the "spring"
Should have taken an hour, but the OE bump stops were rust-welded on, and I had to get the hot wrench on them to get them off.
Also, I went with the 6000 pound units ($295 on e-bay) for the cube van, for your E350, regular van body, the 3600# series should work out fine.
To note, with the "load" I have in the van at all time, I'm tipping the scales at just over 9000#'s and I've had pallets up to 1600# slid in the box, with NO sag in the rear end. And No body roll going down the highway.
Well worth the $$$ for a "over-use" work van
And less that the $560 I spent on the "added 2 leafs" on my old cube van, and ended up with a very stiff ride.
Im50fast
49
01-08-2018 12:21 PM
kincfu
26
02-19-2016 06:17 AM
EconolineFan
11-17-2013 12:48 PM
