F6 Crashbox & Rear Axle Lubrication
Good Afternoon everyone - I was fortunate the other day to find conflicting data between my Ford Shop manual, and a separate manual for Eaton two speed rear ends. Given that 140W oil is recommended for the beloved Warner 4-speed, and the two speed (per the Ford Shop manual), I was prepared to buy a 5 gallon bucket from Napa; however, the Eaton manual recommends 90W for the rear. What are you guys running in: (a) the tranny, and (b) the rear axle? I'd rather use what you've seen work than guess. Thanks!
Thank you for your responses! I'm certainly going to use the 85W-140 oil in the transmission; and will most likely use 80W-90 in the two speed rear axle. The hope now is that this truck will accompany me at least once a week on job sites (once reassembled); and actually haul some commercial roofing products! I just want to ensure that I use the right stuff in the right place ... haha. Thanks again!
big_i80
12-07-2007 08:08 AM
