Use 150 for plowing
I used a 150 for plowing for a while, but it's really hard on the trucks, especially if you're in an area with salt. After a few years it just ate right through the frame and the truck was bending in half. Just as a PSA, make sure you keep you trucks really clean and dry if you can after plowing.
Available on most 4x4 models equipped with the 5.0-liter V8 engine, the dealer installed package adds the wiring, cooling and other features needed to accommodate a plow up to 450 pounds.
Airbag Module Reset Tool
1970f2504x4
09-04-2003 02:58 PM
