Any tricks for oil filter change without a huge mess?
Haven't had the truck long, so haven't needed to change the oil yet. But just looking at it I can tell that removing the old filter is going to make a nasty, oily mess because of its location.
Any tips/tricks to minimizing the mess?
Why can't they design an engine with an easy to reach oil filter anymore, like my old 7.3 diesel had?
it's actually not that bad. I have put 70,000 miles on my truck so I have changed oil in it over 20 times(I've always done it myself). You will notice there is a plastic spill tray in front of the filter that is designed to let the oil slide down. One thing to be aware of is that it will mostly not go down that spillway. It tends to drain down right in front of the front differential. then as you pull the filter out the rest of it goes down that slide. One thing to be aware of is you will need a filter wrench that goes on the end of a socket and at least a 4 inch extension. I found a filter wrench on ebay that is stamped to fit the Motorcraft filter. I had one before that was all purpose, it just grabbed the filter as you loosened and it works good too. But all in all it is not to bad, I have seen a lot worse.
I use a multi size filter wrench that fits on my socket. I unscrew and let the oil drain onto the plastic funnel and then screw the filter off the rest of the way. I then clean the funnel so any remaining oil doesn't drip. The job is not that messy. Make sure the filter gasket comes off with the filter.
