48-51 3 speed trans seal - Ford Truck Enthusiasts Forums
Old 03-31-2014, 02:41 AM
halaferd's Avatar
halaferd
halaferd is offline
halaferd is starting off with a positive reputation.
I'm fixing leaks this week and the rear tail shaft seal on my truck is bad. It's the light duty 3 speed on the floor. It's not the original trans and I'm thinking it's from a 48. Napa shows only one seal but says it's for the automatic.
Is this the same seal for all?
Cast number on trans is:
78-7006-C 3 spd L.Duty
Bearing housing:
21C-7085
Old 03-31-2014, 07:13 AM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Old 03-31-2014, 07:26 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Napa shows only one seal but says it's for the automatic. Is this the same seal for all? No.
Cast number on trans is: 78-7006-C 3 spd L.Duty / Bearing housing: 21C-7085
D9BZ-7052-A (replaced 21C-7052-A - A2TZ-7052-A - C4TZ-7052-A) .. Output Shaft Seal-Use with 21C-7085 and etc / NP (New Process) #96733 / 2.378" O.D. x 1 1/2" I.D. / Obsolete
1949/71 FoMoCo vehicles with 3 M/T O/D / Myriad 1942/80's FoMoCo vehicles with misc 3 & 4 M/T's.
Examples: 1965/71 F100 w/Warner T-85N 3 M/T O/D / 1965/70 Mustang 200/260/289/302 w/Ford type 3.03 3 M/T all syncro trans / 1978/83 Mustang/Fairmont RUG SR-OD 4 M/T O/D.
NAPA should be able to cross any of these Ford part numbers (and the NP number) over to the brands they sell.
Old 03-31-2014, 09:00 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Here's an option. I saw on Doc's '49 that his parts guy matched based on dimensions and came up with National Seal 7692S, which has a nice "boot" on it. It keeps dirt out and if your shaft is getting worn, collects leakage, so it doesn't get flung all over the underside of the truck. I believe it is a C-6 part but works great on mine!
Old 03-31-2014, 10:12 AM
halaferd's Avatar
halaferd
halaferd is offline
Thanks guys, I'll check w my guy at napa and may go the later model seal w the boot if it all looks kosher.
Thanks a lot for the help
Old 03-31-2014, 10:37 AM
Olweldinrig's Avatar
Olweldinrig
Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
I may have another number for you when I can have a look,my neighbor just give me one still in box this fall.Still has leather instead of rubber.nos
Dave
Old 03-31-2014, 12:12 PM
halaferd's Avatar
halaferd
halaferd is offline
Awesome! Yeah I ordered a new oil pan gasket the other day so I won't be getting the seal till it comes in anyway. So no rush, thanks so much
Old 04-01-2014, 09:37 PM
Olweldinrig
Dave
C/R 17599 Might be a little old but...
Old 04-02-2014, 01:42 AM
NumberDummy
This is D9BZ-7052-A (see post 3). It's not for a C6 (that would be D5AZ-7052-A).
emgee
26
03-25-2018 04:21 PM
Potatoehead
03-29-2017 02:49 PM
kens65fb
09-02-2016 08:34 AM
seppo08
09-11-2015 02:45 PM
TCFOMOCO
10-07-2014 08:53 AM
Quick Reply: 48-51 3 speed trans seal
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
