Modular V10 (6.8l)
What Oil & Filter?
Old 05-29-2014, 06:49 PM
SoYouCanSuperDuty's Avatar
SoYouCanSuperDuty
SoYouCanSuperDuty is offline
Ok I remembered that I had the lean codes a few months ago where I had to clean the MAS Airflow sensor. Afterward I eliminated the service engine light by disconnecting the battery, so I never erased those codes. So I'm going to ignore them for now. I am trying to change the spark plugs and the two I tried the bolt for the ignition coils busted, so now I will have to drill and tap those. I soaked the others with WD 40 penetrating oil. Hopefully they will go easier tomorrow. Any advice on removing them so I don't bust anymore?
  #47
Old 05-30-2014, 12:27 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
PB blaster IMO is better than WD40 for penetrating. Some recommend Kroil though. Take your time, use anti-seize on the plugs and cop bolts. Also plenty of die-electric grease on the cop where it connects to the plug. For those small bolts use a 1/4" sized ratchet if you aren't already. For the plugs just go slow trying to preserve the threads.
  #48
Old 05-30-2014, 03:17 PM
SoYouCanSuperDuty
Finished the compression test.
Cylinder 1 - 110
Cylinder 2 - 125
Cylinder 3 - 132
Cylinder 4 - 122
Cylinder 5 - 0
Cylinder 6 - 82
Cylinder 7 - 86
Cylinder 8 - 120
Cylinder 9 - 115
Cylinder 10 - 115
  #49
Old 05-30-2014, 07:09 PM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Cylinder 1 - 110
Cylinder 2 - 125
Cylinder 3 - 132
Cylinder 4 - 122
Cylinder 5 - 0
Cylinder 6 - 82
Cylinder 7 - 86
Cylinder 8 - 120
Cylinder 9 - 115
Cylinder 10 - 115
Did you double check nr 5 ?
Was it a dry or wet compression test?
  #50
Old 05-31-2014, 05:19 AM
SoYouCanSuperDuty
Dry test, with the exception of spraying WD-40 Penertrating oil on the old spark plugs to soak before removal. Tested #5 like 6 times. I just couldn't believe it registered nothing.
  #51
Old 05-31-2014, 08:55 AM
gfl's Avatar
gfl
gfl is offline
a valve stuck open?
  #52
Old 05-31-2014, 09:01 PM
Stumpalump's Avatar
Stumpalump
Stumpalump is offline
5w in a truck during the summer? You guys drank the EPA cool aid.
  #53
Old 06-01-2014, 01:30 AM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Works just fine....
  #54
Old 06-02-2014, 09:36 AM
SoYouCanSuperDuty
Originally Posted by gfl
a valve stuck open?
Yeah that's one of the possiblities. Not sure... I think it would be affecting more cyclinders though... Either way I'm thinking the engine has to go. Where would be the best place to get a rebuild 6.8L Triton?
  #55
Old 06-05-2014, 08:59 AM
SoYouCanSuperDuty
This seems to be the best I've found.
Ford V10 Engines
Anyone order from them or know a better place?
  #56
Old 06-07-2014, 05:41 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
Today I just used Pennzoil Platinum Full Synthetic motor oil with PurePlus in 5w20 ....I used Pennzoil Platinum Full Synthetic motor oil but the Pureplus is new to me.
...Gage
  #57
Old 06-16-2014, 02:12 PM
2004TBIRD's Avatar
2004TBIRD
2004TBIRD is offline
What Oil & Filter
FWIW, have had excellent luck with Amsoil 0W-30 Signature Series oil & Amsoil filter in all my current vehicles 2000 6.8L Excursion, 2004 3.9 TBird, 2010 3.5 SHO.
No consumption between changes on SHO @ 40,000 miles or Tbird with 5000 miles on annual change. (Yes, TBird is rather a toy)
Excursion will be down about half a quart at 1200 miles or so and I was also advised by Ford master mechanic that this was "normal". My counter to him that my wife's two prior Crown Vics modular V-8's used no oil between changes with engines logging 120,000+ miles.
Just traded my daughter's 2003 V-6 Explorer @ 174496 miles - absolutely zero consumption on annual - or 15000 - change. Converted it from Motorcraft 5W-30 dino @ 65,000 miles years ago.
Do not particularly use Amsoil for Eco reasons - just like the idea of once a year change and disposal for 4 vehicles rather than every 3/4 months for each. Also perhaps 5% better fuel mileage than dino - and dino starts shearing by 1000 miles and 5W-20 dino is no longer 5W-20 after 3000 miles. Although not a petroleum engineer, do have an engineering background.
Not a dealer, not trying to sell Amsoil. Just passing along what works for me.
  #58
Old 06-17-2014, 02:13 PM
bolowc's Avatar
bolowc
bolowc is offline
Do you guys have any thoughts on this oil filter? It seems that I have a remote filter mount with one of these:
Lifetime Oil Filters | PurePower! Inc. Lifetime Filters and High Performance Lubricants
  #59
Old 06-17-2014, 02:19 PM
cb_13's Avatar
cb_13
cb_13 is offline
...Gage
The pureplus is the gas to liquid technology that was previously only used in the Pennzoil Ultra line. Appears to be top notch stuff.
  #60
Old 06-17-2014, 09:22 PM
Bently_Coop
It doesnt even appear available for the V10. Why do you need it though when the FL820s can be purchased everywhere? There cheap enough as well and manufactured by Ford.
MichaelKnight
1983 - 2012 Ranger & B-Series
05-15-2018 08:04 PM
ACFX4
1997 - 2003 F150
15
12-06-2009 09:27 AM
mtong0001
2004 - 2008 F150
01-20-2009 09:10 PM
1979f_100
Oil & Lubrication
129
07-06-2007 09:56 AM
PhordPhreek
2004 - 2008 F150
10-07-2005 06:07 AM
Quick Reply: What Oil & Filter?
