Modular V10 (6.8l)
What Oil & Filter?
  #31
Old 04-08-2014, 08:42 PM
fordmerc's Avatar
fordmerc
fordmerc is offline
There is no way for oil to get into the exhaust without first going through a cylinder. Hopefully your new parts make a difference.
  #32
Old 04-08-2014, 09:56 PM
SoYouCanSuperDuty's Avatar
SoYouCanSuperDuty
SoYouCanSuperDuty is offline
Well I don't have a Cat so I guess it could be soot & moisture....
  #33
Old 04-10-2014, 10:30 AM
SoYouCanSuperDuty
Hey guys the parts came in & I installed them, then topped off the oil to the correct level. It was about 1/2Qt low (Was driven less this week.) I will update on oil consumption as thing progress.
  #34
Old 04-10-2014, 12:35 PM
98GP's Avatar
98GP
98GP is offline
  #35
Old 04-27-2014, 05:25 AM
SoYouCanSuperDuty
So to update. Oil consumption is still no better. Still no blue smoke, but that oil is going somewhere... Now my wife is beginning to talk about selling it, because we are about to move cross country, and driving 2K straight on a truck that's drinking a quart every 100mi isn't a good idea... She pointed out that we already spent 2 grand on this truck after buying it... As a shot in the dark I'm gonna try regular dino oil Pennzoil high mileage, and CD-2 Chemical/Heavy duty oil stop leak. I'm not to optimistic though...
  #36
Old 04-30-2014, 09:46 AM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
did you try the blow by test with the fill cap off ?
Stick w motorcraft oil and motorcraft filter.
It almost seems like the oil loss happens when the truck is not being used.
Try to top it off, let it sit for a week or 2 and check the level again.
  #37
Old 05-09-2014, 07:40 AM
SoYouCanSuperDuty
Truck sat a little while working on the fron steering (Making Poorly Installed Lift Kit Right.). Oil was fine, but still disappearing when used. I will do a blow by test this weekend, but I doubt I will like the results.
  #38
Old 05-09-2014, 08:51 AM
SoYouCanSuperDuty
Since it's still burning oil I guess I will revert back to Motorcraft 5W20. Not gonna change the oil though, just replace what disappears with Motorcraft. Shouldn't hurt anything right?
  #39
Old 05-09-2014, 08:57 AM
98GP's Avatar
98GP
98GP is offline
Update on mine...
I have noticed that my oil consumption has slowed since my new PCV valve and hose. Still watching.
I am due for an oil change. I will make sure I record miles at oil change and every dip stick check after to measure the oil consumption and verify it has slowed.
  #40
Old 05-19-2014, 11:20 AM
SoYouCanSuperDuty
Ok... So now I notice blue smoke during idle and now got these diagnostic codes.
P1000- OBD-11 Monitor checks incomplete, require another drive cycle.
P0171- System to lean. (Right cylinder bank.)
P0174- System to lean. (Left cylinder bank.)
P0303- Cylinder #3 Misfire Detected.
P0305- Cylinder #5 Misfire Detected.
P0306- Cylinder #6 Misfire Detected.
P0310- Cylinder #10 Misfire Detected.
  #41
Old 05-19-2014, 02:22 PM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Focus on the lean part first.
Could be misfiring because it is lean.
First check intake tract. Any opening after the MAF will cause a lean. Holes, bad gasket..etc.
Next up could be o2 sensors.. but it's both sides so unlikely.
  #42
Old 05-20-2014, 06:53 PM
SoYouCanSuperDuty
Was talking with a buddy of mine and he said that this engine is prone to broken spark plugs, and blown spark plugs. He said it might be that the oil cumsumption could be caused by the spark plugs possibly cracking and messing up the Vaccumm. Do you guys think that's possible? With the error codes I got replacing the spark plugs may be a good idea, but not looking to spend anymore money if the engine has to go. Especially since worst cause on the spark plugs may require retapping with a timesert Kit.
  #43
Old 05-20-2014, 09:15 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Should be fine when replacing the oil.
First thing like AZ mentioned is to change out the O2 Sensors. Then start on the misfires. I would actually leave the battery plugged in when replacing the sensors so you can go to the parts store and use there scanner after to see if the codes dissappeared.
For the Misfires get a couple motorcraft coils and change them out one at a time with the appropriate cylinder.
  #44
Old 05-23-2014, 08:52 AM
SoYouCanSuperDuty
I really appreciate the help, but my major frustration is the codes are giving me the indication that the spark plugs are being fouled by bad piston rings since I have so much oil consumption with blue smoke now. So could the spark plugs be causing the oil consumption or just be a symptom of the consumption? I would love to change out the O2 sensors and give it a tune up if that eliminates all the problems, but don't want to keep spending money if its time for a new engine ore rebuild. I have heard the theory of bad sparkplugs possibly causing oil consumption, but it sounds far fetch to me. I don't want to put more money into the engine if I should be saving for a new one.
  #45
Old 05-23-2014, 10:24 AM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
I don't see how spark plugs can cause oil consumption.
Have you checked the intake tract for leaks ? It's saying too lean... MEans you have unmetered air coming in. I don't think the o2's are bad since both sensors report lean... Highly unlikely that they go bad both at the same time.
again, don't focus on the misfires but focus on the lean indications first.
Quick Reply: What Oil & Filter?
