Modular V10 (6.8l)
What Oil & Filter?
Old Apr 3, 2014 | 07:51 AM
Im50fast's Avatar
Im50fast
Originally Posted by SoYouCanSuperDuty
Sounds good. I'll keep updating too. Your truck still have have horsepower?
Yes, mine has tons of power. I've had it 10 months and driven about 35,000 miles. During all of my ownership it has spark knock at heavy/medium throttle. 100% spark knock at high rpm/high throttle. I experimented with higher octane fuel and it eliminated the spark knock, but it decreased my economy by about 1.5 to 2.5 mpg. But maybe that's from digging into the Fun Pedal to test the spark knock.
Regarding oil loss; I did an oil change a few weeks ago with Mobil 1 full synthetic 5W20, and I checked it exactly 1,000miles later. It was about a quart low.
Exactly another 1,000miles later checked it again, and it was a quart low again. Both times I added Mobil 1 full synthetic 5W20.
I guess these engines just sip some black gold as a side item to guzzling gasoline.
Old Apr 3, 2014 | 09:24 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Originally Posted by Im50fast
I am currently experimenting with my V10 oil loss. For the last 9 months it seems I lose 3-5 quarts between oil changes. No smoke, no leaks, not in coolant.
I have been using Motorcraft 5-20 synthetic blend.
Last oil change I got full syn Mobil 1 5w20. I'll keep you posted.
What I would do is check all the oil vapor recovery system, start with the PCV valve and then the hose that is connected opposite valve cover and oil fill cap. Make sure it can draw no outside air, so you have to check all the fittings and hoses.
Denny
Old Apr 4, 2014 | 11:02 PM
98GP's Avatar
98GP
Me Too!
I have a "thirsty for black gold" V10 in a 2005 Ex. I am see about a quart consumed every 1K miles too.
rvpuller (AKA Denny)
I replaced the PCV valve and PCV valve hose a couple weeks ago. The old PCV valve rattled, but not as freely as the new one. I could also blow both directions on the old but not the new one. It has not changed the oil consumption. I have not removed and inspected the hose on the drivers side valve cover but I do not see any oil resdue on the valve cover like I did on the valve cover w/the PCV valve.
What needs to be looked at in regards to the oil fill cap?
I think its unrelated, but can an exhaust leak due to broken manifold studs cause this?
I cannot see anything else wrong...no spotting on the driveway, no excessive smoke, no oil in the coolant/coolant in the oil, engine runs strong, no weird noises, IDK...this is getting old! These engines should not be using this much oil.
Does my V10 need a valve job or replace heads?
Getting frustrated...
Old Apr 5, 2014 | 11:18 AM
rvpuller's Avatar
rvpuller
The oil cap has a seal on it to stop air from being pulled into the crankcase also check and make sure the dip stick is sealed.
The crankcase ventilation system works by pulling a vacuum on the crankcase under load to draw any oil vapor back into the motor caused by compresion leakage or blow by and burning it instead of it venting into the atmosphere. If air can be pulled in anywhere else it will cause normal oil vapor in the motor to be pulled into the pcv valve and burned, the tube going into the left valve cover balances the system because of where it's connected to the air intake tube.
If you want a fast and easy way to check and see if your oil consumption is from engine wear, with a warm motor remove the oil filler cap, block the wheels, set the emergency brake, put the transmission into gear and step on the gas. If you get a large amount of oil vapor coming out of oil fill under load the rings are allowing compression into the crankcase, time for a rebuild.
Denny
Denny
Old Apr 5, 2014 | 12:51 PM
98GP's Avatar
98GP
The Ex only has 125K miles. Do you think a rebuilt is necessary already?
I will try the engine load test. How long will it take to get oil vapor to expel from the fill port and what rpm will this occur?
Thanks
Old Apr 5, 2014 | 01:02 PM
rvpuller's Avatar
rvpuller
Thanks
At a 125K it shouldn't need a rebuild if it's been maintained. The oil vapor will come out right away, and not just drift out it will shoot out.
Denny
Old Apr 6, 2014 | 05:40 AM
Im50fast's Avatar
Im50fast
Ford specs indicate up to 1 quart per 1,000miles is normal.
Old Apr 6, 2014 | 05:49 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i run mobile 1 full synthetic and motorcraft filters in all my V10's (two previous) and my current one. i switched this truck over at 100k and now at 134k i change every 5-6k miles with about 1.5-2qt loss over that time (estimated) since i check it often and top it off a little at a time.
Old Apr 6, 2014 | 09:29 AM
SoYouCanSuperDuty's Avatar
SoYouCanSuperDuty
To update I lost 2 QTs of Motorcraft Synthetic blend so far thats 1 week & around 200 - 300 miles. So the Motorcraft is faring no better or worse than the Mobil 1. Didn't get to pull spark plugs or do a compression test yet. PCV Valve was changed a month ago. Checked drivers side valve cover hose. It had some oil & fuel residue in it. Gonna order a replacement & see how that does.
Old Apr 6, 2014 | 10:28 AM
98GP's Avatar
98GP
So are you all saying I should just live with this oil consumption?
My old TJ Wrangler I had didn't use a single drop of oil. Some days I wish I never sold that thing for this Excursion.
Old Apr 6, 2014 | 10:58 AM
SoYouCanSuperDuty
Sounds like we are in the same boat. Check the crankcase breather hose. Mine showed little signs of oil too. But when I pulled It there was oil on the barb. I' gonna change oil fill cap, dipstick, & crankcase breather hose, and see what that does. The parts are cheap so it worth a shot.
Old Apr 6, 2014 | 01:05 PM
cb_13's Avatar
cb_13
Make sure to install a Motorcraft or other pcv valve specific to your application. I have seen consumption issues caused by some of the parts store/walmart pcv's that are listed as correct because they fit in the hole. Not sure if they were junk out of the box or just built different somehow.
Old Apr 6, 2014 | 01:16 PM
  #28
SoYouCanSuperDuty
Thanks yeah going Motorcraft. All the parts together is under $50. Got part numbers calling dealer tomorrow.
Old Apr 6, 2014 | 05:38 PM
  #29
chuckadian's Avatar
chuckadian
I've always used Wix filters and Royal Purple 5w20 oil. So far so good!
Old Apr 8, 2014 | 08:29 PM
  #30
SoYouCanSuperDuty
So as a update I ordered the parts I mentioned earlier from FordParts.com. Looking like 3-8 Days to come in. Today I noticed that my exhaust still does not show any smoke white or black, but the exhaust terminates right before the passenger side rear axle, and my once white & red shock is now black. The exhaust tip had what looked to be a little oil on the tip. Doesn't seem like the oil is being burnt in the cylinder (like bad piston rings or such.) But is being lost thorough the exhaust.... Hoping that the change of the crankcase breather hose will remedy this since it goes from the drivers side valve cover to the air intake of the throttle. Still this is making me nervous...
