Truck work start when I turn the key
I have a 1972 f250 camper special. I turn the key and nothing happens. if I jump the connection at the starter solenoid it will start. Also its a new starter solenoid I used an ignition out of my other truck and it did not start. using the test light I found that the positive side on the small wire is always hot but weak. I am not sure where to go from here.
Neutral safety switch is an easy one to check...located on top of steering column tube.
Edit: which would be great advise if I knew it was an auto and I wasn't backing my location with 73-79 experience. LOL...sucks when ya forget what forum your in....first thing to go is the memory...sheesh.
Do you have the solenoid on the wall as well as the starter. If you do then there is a way to wire it too work .... I had to do it myself befriend me and I can get you more details. I would have posted it up already but due to crappy weather I haven't. Good weather is on its way this weekend
dmilner1970
05-04-2011 06:43 PM
Ryan86F250
08-01-2008 11:54 PM
