New wheels 15 x ???
New wheels 15 x ???
Since I'm towing a Casita with the AWD and can't get decent 14" tires anymore I want to upgrade to 15". Wondering how wide anyone has gone without rubbing the front tires on the wheel well. General opinion seems to be that the OEM 15x7's will work but the original wheels are 14x6. Any opinions out there or should I hunt down maybe a 16.5. The wider wheels should, I hope, help with some of the sway. Already replaced the springs and struts front and back but the sidewalls on the tires still make it a mushy side to side ride. ???
14 to 15" wheel conversion
Okay, I've read a ton of discussion on this forum about this conversion since you can't get decent 14" tires anymore. Check this link for everything you need to know about what works. Size, lug pattern, offset for most every car. There ya go.
http://www.roadkillcustoms.com/hot-r...#axzz2x7fpTWJa
94/95 Mustang 15x7 215/75/15
Hi
I have run both a 205x75x15 on a Mustang 94 alloy wheel and a 225/60/16 mustang wheel on several Aerostars. They 16 is more responsive, lower profile. More expensive tires.
The 205's are a little bit thinner, quieter and get slightly better gas mileage.
Both fit easily, speedo is very close within 1-2 mph @ 65.
Both are load rated beyond the original specifications. For AWD I would choose a 205/75 or 215/70 15 as to be sure to minimize wear on the drive train.
I did run the 225 16's on my AWD this winter as they are studded snow tires.
Watch out for newer mustang wheels offset is different and caps may not fit.
Look at my 96 and you will see how clean they look.
Stoney
01-30-2006 07:22 PM
